I'm working on a project with a lot of external peripherals, so this means lots of wires. Any recommendations on how to keep them tidy while working on it? I don't want to use cable ties just yet, as I need to keep moving them so would have to keep cutting the cable ties.
I like to use Velcro Cable ties. Basically used the same way as ones you would have to cut, but instead you just have to pull them apart.
Depending on what you are doing a Wire Duct might benefit you more. They tend to get more messy on the inside, but can produce neater results on the outside.
- "flexible plastic conduit"
- "corrugated flex tubing"
- "split loom"
I'm having trouble finding a good search term for it, but I've used flexible plastic/PVC wire conduit to bundle wires together in text fixtures outside of enclosures. The stuff is commonly used in wire harnesses, especially in automotive.
It's essentially a thin, corrugated plastic hose with a slit running through it so you can shove in or pull out cables and wires, available in a wide range of sizes, from about 1/4" (almost pointless; fits about (3) 16-AWG wires) up to 2".
\$\begingroup\$ I've used this for a variety of projects and it looks good and is easy to use. \$\endgroup\$– RQDQMar 6, 2011 at 22:33
\$\begingroup\$ The 1/4" tubing is awesome for about 8x 22AWG wires. They tend to make it into hobby projects though, since there aren't (or shouldn't be) any 22AWG mains plugs. \$\endgroup\$ Aug 7, 2012 at 17:20
Not sure where you can get it, but I've encountered this stuff that looks like spirally-cut polyethylene tubing. The stuff I've seen comes on a big reel, and you cut off as much or as little as you need. So you lop off a few inches of it, and then wind it around the wires/cables you want to bundle. It's very quick to put to use, it's quick to take off, it's re-usable, and it's neat, too.
\$\begingroup\$ Is this the thing you mean? maplin.co.uk/spiral-cable-wrap-26849 BTW i live in the UK and have a maplin local. \$\endgroup\$– DeanMar 5, 2011 at 0:05
\$\begingroup\$ @Dean - yes, if that isn't the actual same stuff, it is certainly the same concept. \$\endgroup\$– JustJeffMar 5, 2011 at 1:15
Using twist ties to shorthen cables is a very simple first step, gets rid of long lengths of cable waiting to get tangled.
Insulation tape... cheap, firm hold, easy to remove.
\$\begingroup\$ It looks a tad on the messy and unprofessional side though. But still good. \$\endgroup\$– capcomJan 13, 2013 at 5:29
I don't know what this is called, but I think this would help.
