Is a 250V and 660W lamp compatible with both:
  • 120VAC at 60Hz, and
  • 220VAC at 50Hz?
And why? Also, does the frequency of the mains have any bearing on the lamp?
In North America I was very surprised to notice a lamp certified for 250V but plugged into an 120VAC mains. My naive intuition is that the lamp should be certified for 120V. And similarly, the same 250V lamp would probably be compatible with a 220VAC mains (as in Europe), but I would have expected that a lamp in Europe should be certified for 220V.
But I'm most likely wrong here, so:
Why is a 250V lamp compatible with both 120VAC and 220VAC mains?
PS To avoid confusion, by "lamp" I mean a light fixture and NOT a light bulb.
  • \$\begingroup\$ What kind of lamp? Incandescent, fluorescent bulb, ballast based or led? \$\endgroup\$ May 14, 2014 at 23:58
    \$\begingroup\$ Do you mean the fixture is certified for 250V? But maybe the bulb in the fixture is 120V? The same fixture may be used with a higher voltage bulb where higher voltages are used, no confusion there. \$\endgroup\$
    – casualuser
    May 15, 2014 at 1:51
6
I see that you're referring to the light fixture itself. In this case, the rating is the maximum that the fixture construction can withstand. Remember that the fixture is really only wires, switches, and connectors. It only serves to pass the current from the wall to the light bulb.
In your case, the fixture can handle any voltage up to 250V. You can use a 120V or a 240V bulb. The bulb would have to match the mains voltage.
660W is the largest bulb the fixture has been designed for, so that nothing gets too hot and/or melts. You can use a smaller-wattage bulb.
And the frequency doesn't matter to the fixture, although the bulb you choose might be affected (but probably not...)
That was the simple answer, but there is another consideration. Thanks to @david for pointing it out.
The ratings on the fixture should include maximum voltage and maximum current. The maximum voltage is simply the highest voltage that the fixture is rated to withstand, without arcing or breaking down in some fashion.
The maximum current, if given, will be independent of voltage. Often, however, the manufacturer will use a power rating instead of a current rating (660W in this example). To do this, they have to make some assumptions about the incoming voltage. Those assumptions reflect the manufacturer's expectations of where the product will be used.
For example, a 660W bulb draws 5.5A at 120V, or 2.75A at 240V. Were they expecting a 120V lamp? Probably so, if it was sold in an area that uses 120V. So, they chose wire that can handle 5.5A (or higher). Since this will also work with a 240V bulb, there is no problem.
But, say that you are using a 24V bulb (assuming you had a 24VAC power source). The fixture could certainly handle the voltage, and should work fine. However, if the bulb was 660W (the fixture's "maximum"), then the required current would be 27.5A. The wiring in the fixture will almost certainly fail at this current.
So, if in doubt, check to see if there is a current rating on the fixture :)
  • \$\begingroup\$ Note: it probably can't handle 24V. That is, not with a 660W globe. Explicitly or implicitly there is also a current limit for the wiring and switch, and it might be rated to handle twice the expected current, but not 10 times. \$\endgroup\$
    – david
    May 15, 2014 at 10:36
  • \$\begingroup\$ @david I had mentioned 24V to help conceptually, but I see your point. I've changed my answer. Thanks. \$\endgroup\$
    – bitsmack
    May 15, 2014 at 12:51
  • \$\begingroup\$ Very interesting. I believe that the 660W is an extreme-case scenario. I suspect that this light fixture should work just fine with a 10W LED light bulb in both 120VAC/60Hz and 220VAC/50Hz mains, correct? (Assuming of course that the light bulb itself is rated for both 120VAC and 220VAC mains.) \$\endgroup\$
    – landroni
    May 16, 2014 at 18:04
    \$\begingroup\$ @landroni Should be fine. If we use the most conservative assumptions (660W at 250V), this gives 2.64A. So, their internal wiring must handle that much, although it likely handles much more. A 10W bulb only draws 0.042A at 240V, or 0.083A at 120V. (or 0.42A at 24V!) It doesn't even come close to the limit. \$\endgroup\$
    – bitsmack
    May 16, 2014 at 18:20
    \$\begingroup\$ @landroni That's a little more tricky, as it depends on whatever circuitry they used inside the bulb. I expect it will be just fine, though! The only possible problems that I can imagine would be 1) it's slightly less efficient (runs hotter), or 2) there may be a visible flicker. But I expect you won't see these problems :) \$\endgroup\$
    – bitsmack
    May 16, 2014 at 19:13
It may be made so the filament can stand up to 250 Volts, or it may draw less current at 220 volts than at 120, so the watts would be the same in either case. 10 Hz in frequency shouldn't make a difference.
