I am doing some radio work, and I assume you can use a bandpass filter to reduce the bandwidth of a received signal. The application is modifying schematics for a FM broadcast receiver to a 5-25 kHz bandwidth of received signal ham receiver. Is that correct?
  • \$\begingroup\$ Are you talking modulated carrier or demodulated signal and, presumably you mean 5 Hz to 25 kHz? \$\endgroup\$
    May 15 '14 at 14:22
  • \$\begingroup\$ I am talking about the modulated carrier, and the 5-25 KHz is the bandwidth of the FM signal received. \$\endgroup\$
    – Delta1X
    May 15 '14 at 14:52
  • \$\begingroup\$ 5 Hz or 5 kHz as per my question. \$\endgroup\$
    May 15 '14 at 14:55
If you are talking about applying a bandpass filter to the modulated carrier then no, this will not restrict the bandwidth of your demodulated signal. That's not how FM works. The amplitude of the modulating signal determines how far off-centre the carrier is pushed.
It sounds like your unmodulated carrier is 15 kHz and the modulating signal pushes this up to 25 kHz and down to 5kHz - quote "5-25 KHz is the bandwidth of the FM signal received". Applying a bandpass filter to this will reduce the amplitudes of the frequencies at 5 kHz and at 25 kHz but any half decent FM demodulator will still convert these reduced levels into the appropriate demodulated signal.
  • \$\begingroup\$ The idea was to use filters to convert a 200KHz bandwidth receiver to a receiver that can tune 5-15 KHz (amateur radio narrowband FM) signals and 15-25 KHz ( amateur radio wideband FM) signals without receiving an additional 175 KHz of bandnoise/signals. If using bandpass filters on the modulated carrier wouldn't work, do you have any suggestions? Thanks for the answer +1 \$\endgroup\$
    – Delta1X
    May 15 '14 at 15:11
  • \$\begingroup\$ If the carrier is narrow modulated then it shouldn't be a problem but you might need to tweak the demodulator to get more gain out of it. \$\endgroup\$
    May 15 '14 at 17:35
