What is the difference between Atmel ICE, Atmel SAM-ICE and Atmel JTAGICE mkII?
From what I understand, Atmel ICE is cheaper and better in every way, support more families, thus why would one buy the other one?
Electrical Engineering Stack Exchange is a question and answer site for electronics and electrical engineering professionals, students, and enthusiasts. It only takes a minute to sign up.
Sign up to join this communityWhat is the difference between Atmel ICE, Atmel SAM-ICE and Atmel JTAGICE mkII?
There are some points that you have to contemplate.
Yeah, I know that the Atmel-ICE can support a wide range of the Atmel products but I can guess that many compilers or IDEs don't support it.
For instance, when you work with Keil and have bought it, you don't want to buy an Atmel-ICE because the Keil can't support it.
If you buy an Atmel SAM-ICE, you will have a chance to use it in Keil because the Keil supports it as a J-Link debugger.
On the other hand, if you notice, the Atmel-ICE doesn't support AT91 while the Atmel SAM-ICE does; or for another example, the Atmel JTAGICE mkII has an on-board 512kB SRAM for fast statement-level stepping but the Atmel-ICE doesn't.
I hope this answer will help you.
As I have just found out, the Atmel-ICE does not support the high-end ARM cores (Cortex-A5, etc) and only supports Cortex-M. In other words, if you want to use the SAMA5 MPUs, you'll need the SAM-ICE.
