I have a 13 bus system that I want to apply Newton Raphson to. 3 of the buses have generators. So that makes 1 slack bus and 2 PV buses. 6 of the buses are connected to loads (PQ). 5 buses have transformers. I have no clue how to handle transformers when doing load flow analysis. I converted them to impedances in pu. I'm not sure what the next step is.
The circuit and specs are shown below... 13 bus system
13 bus system specs
In power flows a transformer can be modelled exactly the same as a line if the per unit system is used. Therefore you can safely model them as impedances.
Check out the page 21 (bracnhes modelling chapter) of the Matpower manual: http://www.pserc.cornell.edu/matpower/manual.pdf
  • \$\begingroup\$ the link is unfortunately dead \$\endgroup\$ – user3209815 Jun 2 '16 at 9:19
  • \$\begingroup\$ Edited the answer with a working link \$\endgroup\$ – Santi Peñate-Vera Jun 3 '16 at 7:52
