I have a 24V battery charger that got wired in backwards and it fried one of the diodes. The codes on the diode are:
STPS30
150CW
U4D409
I have found one which I think should work, but could someone with a bit more knowledge please check it for me?
http://uk.rs-online.com/web/p/rectifier-schottky-diodes/4858140P/
It has the same part number. Of course it would work.
Anyway, if you couldn't find exactly the same diode you would have looked for a diode with:
  • a current rating equal or greater than the original one
  • a reverse voltage equal or greater than the original one
You could even use two single diodes instead of it (of course with the same or greater ratings).
