I want to trigger a LED with both an Arduino and a hardware switch without coding any button logic in the Arduino.
When the button is pressed there is a direct connection between the 5V power supply and Arduino pin 17. Can this do any harm? Is there a better solution?
What you have drawn is a bad idea. If the Arduino output is low when the button is pressed, the 5V bus will be shorted. That's really bad. Instead, do something like this.
  • \$\begingroup\$ You use the 2N3904 to avoid current flowing back to the Arduino output? \$\endgroup\$ Commented May 19, 2014 at 14:28
  • \$\begingroup\$ You could run the output open drain, but I prefer to switch LEDs with an external transistor. There is no reason for the micro to have to sink that current. \$\endgroup\$
    – Matt Young
    Commented May 19, 2014 at 14:39
  • \$\begingroup\$ OK, if I replace the LED with a relay, do I still need R1? \$\endgroup\$ Commented May 19, 2014 at 14:47
  • \$\begingroup\$ Yes, R1 is here to limit the current into the LED. \$\endgroup\$
    – Blup1980
    Commented May 19, 2014 at 14:49
  • \$\begingroup\$ You do not need R1 if you replace the LED with a relay. But you will need a catch diode in parallel with the relay (reverse biased). \$\endgroup\$
    – akellyirl
    Commented May 19, 2014 at 14:52
Yes. There is a much better solution.
First off you need a resistor in series with your LED. Connect the resistor from the +5V and then to anode of the LED.
The switch would connect from the cathode of the LED to GND. When pressed the LED will go on.
The Arduino output needs to be operated in a mode where it changes from Input to Output@0 for its switching activity. Connect the output to the cathode of the LED. Under no circumstances should your software ever set the output pin to a '1' high level. You want to avoid the situation where a high output level can get shorted to GND by pressing the switch. To turn the LED on the pin is set low '0' as an output. To turn off the LED the pin is set to input mode.
