6
I'm an Electrical Engineer, and understand how a twisted pair of wires can be used to reduce noise in the presence of magnetic fields.
However, I recently noticed the power company replacing the cables on a high voltage transmission system with a twisted pair of cables. The top most ground cable is still a single cable, but they now use two cables twisted in a pair for each of the 3 power cables as shown here. Twisted Cable Pair
Why do they use these types of cables?
EDIT: After reading the answers by WhatRoughBeast and Waqar, it would seem that the most plausible explanation for using 2 cables would be current capacity versus weight, but there must be more to it than that.
The engineers that designed these transmission systems 30 years ago weren't stupid. They certainly knew about skin depth, and could easily calculate the optimal cable size and number of cables to use.
As far as I can tell, this idea of using multiple cables for each phase is relatively new. I recently noticed that in some cases, they use multiple sets of two cables for each phase.
    \$\begingroup\$ @IgnacioVazquez-Abrams: Sorry, but no. He's talking about high voltage towers. These use air insulation between the voltages, and the twisted pairs must carry the same voltage on each conductor of the pair. \$\endgroup\$ May 19 '14 at 22:45
  • \$\begingroup\$ Bear in mind that 30 years ago copper was cheap, manufacturing time/complexity was expensive. \$\endgroup\$
    – John U
    May 20 '14 at 19:01
    \$\begingroup\$ The single cable lines being replaced were aluminum, not copper, so that wouldn't seem to be a factor. Also, I would guess that because of increased regulation, manufacturing costs are higher today than 30 years ago. \$\endgroup\$ May 22 '14 at 17:25
10
After nearly 2 years, I found the answer to my question.
I recently walked past an electric utility's storage yard and noticed this reel of twisted pair cable. enter image description here
The manufacturer is Southwire Company of Carrollton, Georgia and the cable is called VR2, Vibration Resistant Cable.
Their web page says VR2 uses a twist to provide resistance to Aeolian vibration and ice galloping.
Since I had never heard of Aeolian vibration, here is a quote from this article titled: "Aeolian Vibration Basics" en-ml-1007-4aeolianvibook-1.pdf
When a smooth stream of air passes across a cylindrical shape, such as a conductor or OHSW, vortices (eddies) are formed on the leeward side (back side). These vortices alternate from the top and bottom surfaces, and create alternating pressures that tend to produce movement at right angles to the direction of the air flow. This is the mechanism that causes aeolian vibration.
Here is an example of an Aeolian Vibration Failure. Aeolian Vibration Failure
Here is a YouTube clip showing these vibrations.
    \$\begingroup\$ Aeolian harp. An Aeolian harp (also wind harp) is a musical instrument that is played by the wind. Named for Aeolus, the ancient Greek god of the wind. \$\endgroup\$
    – Transistor
    Jan 16 '16 at 10:56
    \$\begingroup\$ The phenomenon is also know as vortex-induced vibration. \$\endgroup\$ Jan 16 '16 at 13:50
    \$\begingroup\$ The Preformed Line Products article "Aeolian Vibration Basics" is quite interesting because it describes Aeolian Vibration in some detail and shows several types of cable failure. It also shows some of the unusual hardware the power companies use to control these vibrations. (Google the article name, I couldn't find a direct link.) \$\endgroup\$ Jan 16 '16 at 14:10
At a guess, they're doubling the current capacity of the lines. If, instead of a pair of wires, they had used a single wire 40% thicker, the wire would have been noticeably stiffer and harder to spool and unspool for transportation and installation. The reason they're twisted is not for reasons of noise susceptibility or anything like that - it's to provide mechanical support for the wires, and makes the pair stronger than they would be if they were not twisted together.
  • \$\begingroup\$ It's stranded wire but with only 2 strands. And most likely the wires they are using as those strands are stranded themselves if they carry HV AC. \$\endgroup\$
    – Dan D.
    May 20 '14 at 2:25
One possible benefit is reduction of corona discharge. This article states,
The electric field gradient is greatest at the surface of the conductor. Large-diameter conductors have lower electric field gradients at the conductor surface and, hence, lower corona than smaller conductors, everything else being equal. The conductors chosen for the Calumet to the line were selected to have large diameters and to utilize a two conductor bundle. This reduces the potential to create audible noise.
In my country it is common to see four 'bundled' conductors per phase with 'X' spacers at intervals between the pylons to maintain the desired separation. This article from India gives some details on the technique. The OP's conductors are in contact but perhaps there is still some benefit.
  • \$\begingroup\$ I don't think this cable is used is to reduce corona. First, Southwire, the cable manufacturer, clearly states that this cable was designed to be vibration resistant, hence the product name, VR2. Secondly, I don't know what the line voltage is, but the insulators are only about 0.5 meter long, and the poles are only about 6 - 7 meters tall. Lastly, I have noticed for many years all sorts of Aeolian vibration reduction hardware hanging from the power lines, without knowing what it was for. Apparently, Aeolian vibration is a big problem in my area. \$\endgroup\$ Jan 18 '16 at 13:24
  • \$\begingroup\$ All points taken. I was interested in your comment on Aeolian vibration as I'd never heard of it before although I was aware of the Aeolian harp. I left a link on the subject on the OP. \$\endgroup\$
    – Transistor
    Jan 18 '16 at 14:32
There are a lot of advantages for doing that
  1. As @WhatRoughBeast said, current capacity. For same amount (and hence weight) of conductor.
  2. As you know AC currents flow closer to surface in a conductor than flowing evenly in each part (Skin effect), so one thicker cable will be loss of metal on the inside.
  3. Heard of solenoids? This twisted conductor pair creates a similar effect (although not exact because twists are not exact close circles) and keeps magnetic field induced at minimum outside of pair. More twists/inch are better for field cancellation but increase the current path length (and so heat losses) so a trade off is done.
Top ground wire is for protection and most of the time no currents are flowing through it. (Generally speaking, they use a delta circuit for HV lines) So no need to replace it.
  • \$\begingroup\$ To point #3, this is only when the return path is part of the pair, as in POTS, USB, or ethernet \$\endgroup\$
    – EkriirkE
    May 20 '14 at 4:08
  • \$\begingroup\$ @EkriirkE: If wires in pair are carrying currents in opposite direction then it kills induced magnetic field inside as well. Single direction current in solenoid is enough to remove outside magnetic field. \$\endgroup\$ May 20 '14 at 4:17
  • \$\begingroup\$ Point 3 is invalid as an answer - there will be no antiphase cancellation in HV power wiring. \$\endgroup\$
    May 20 '14 at 7:37
  • \$\begingroup\$ may be, I explained benefits of twisted wire, question states that provider there is using twisted pair for power dist/tx whether HV or LV. \$\endgroup\$ May 20 '14 at 7:56
