I'm trying to design a relay circuit for my first PCB and have come up with the following:
- The 10K value for R7 is just a placeholder. R7 is what I'm trying to determine.
- The transistor should turn the relay on and off based on whether D2 is at 5V or GND.
- The relay is a 5V relay and has a coil resistance of 63 Ohms, so the coil current is 79.4mA.
How do I determine what value the base resistor (R7) should have for the circuit to work?
Datasheets: Relay, Diode, Transistor
My attempt:
Ic = 80mA (relay current) + [5V-Vce]/10K (current through LED)
Ic = 80mA (relay current) + [5V-0.5]/10K (current through LED)
Ic = 80mA + 0.45mA = 80.45mA
Ic = hFE*Ib
Ib = Ic/hFE
Ib = 80.45mA/120 = 670uA
Ib = [5V (D2 high voltage) - 1.2V (base-emitter saturation voltage from datasheet)] / R7
R7 = [5V-1.2V]/Ib
R7 = 3.8V/670uA
R7 = 5672 Ohms
So, according to my calculations, the base resistor should be ~5.6 kOhms. However, I have no idea whether did this correctly or not.
