I have a system with two DSP modules. The audio is routed from DSP1 to DSP2 and then back to DSP1, which in turn immediately sends it to DAC. It's a high-quality stereo sound at 44.1KHz.
This is a requirement, there should be two DSPs and routing can't be changed.
The problem is the clocks. Each DSP module has its own internal clock, which can't be ideally synchronised. I set the rate numerically on both, but the result is that I get a slightly glitchy sound, for obvious reasons.
One solution would be, of course, to feed the clock from one DSP to the other, but at this time this is a bit problematic for me.
Is there another way around this? E.g. a relatively simple algorithm that can compensate little differences between clocks? Any other ideas?
Edit: the connection between the DSPs is I2S. Either module can operate in master mode, but it doesn't help.
