I need to connect a bunch of Mass Flow Controllers on a RS485 (TIA-485-A) multipoint bus. I will use Modbus protocol to communicate with the devices.
As specified on modbus.org (Specification and Implementation guidelines), the serial bus infrastructure in a multipoint Serial Line system is like this:
Modbus connectors
In my project, I would need only the Passive TAP (no Active TAP), because the length of my cables are around 10 cm.
From the mechanical point of view, 2 types of connectors are specified. The RJ45, and the D-shell 9-pin, as depicted below.
Modbus - serial bus infrastructure
My question is, what can I found on the market as Passive TAP with either RJ45 or D-Shell 9-pin connectors?
Something like this with RJ45/D-Shell instead M12 would be nice. enter image description here
Likewise, L-Com (http://www.l-com.com) makes a DB9 Y splitter, available on the web.
  • \$\begingroup\$ Excellent! It´s exactly what I was dreaming of. \$\endgroup\$
    – RawBean
    Commented May 22, 2014 at 20:11
There are RJ45 Y-splitters on the market, to be used for ISDN. These are completely passive and wired one-to-one.
