For a battery powered ultra low consumption application I designed a classical high side switch using the complementary MOSFET FDMA1032CZ. this is the schematic:
The idea is simple:
  • before shipping, the circuit consumption is nearly 0[A] (only MOSFET and battery leaks),
  • then the user powers on the circuit using switch S1,
  • the microcontroller starts running and activates Q1-N and Q1-P via "PWR_ON" signal,
  • the circuit is then continuously powered on by the battery through the mosfet switch.
I need assistance to calculate the optimal value for both pull-up and pull-down resistors (R1 and R2). For reminder, those 2 resistors are mandatory to set voltage level when circuit is powered on.
In my opinion those resistors must be :
  1. as large as possible to minimize current when the 2 mosfets are on,
  2. but not too big to make sure the 2 mosfets can switch fully on.
When looking at datasheet, it appears that the maximum MOSFET gate body leakage IGSS_max = +/-10[uA] and the minimum gate threshold voltage VGSth_min = +/-0.6[V].
According to previous point 2), the resistor value should NOT be greater than R_max = VGSth_min/IGSS_max = 0.6/10e-6 = 60[kohm].
For a battery voltage of 3V, this would result in a total consumption through the resistors of: I = 2x V_BAT/R = 2x 3/60e3 = 100[uA], which is far too big...
I would appreciate if someone could confirm and/or correct my calculation.
It seems your calculations are correct.
This IGSS is untypically high for mosfets. I think this is because of zener diodes on gate. Typical value is ±100 nA.
|improve this answer|||||
The common reasons for including that resistors are as follows:
R2: To avoid leaving the gate of Q1-N in a floating state and thus avoid unwanted conduction in specific situations . For example, when the microcontroller is powered but not yet executed the code that configures the I/O system (in your case, to write a high value on PWR_ON) or in forced reset caused by noise and watchdog activation.
R1: As Q1-N cannot impose a high level in the Q1-P gate, the turn-off of this mosfet depends exclusively on the discharge of its GS capacitor through R1.
The exact value of each resistor is not critical. However, they influence the mosfet turn-off time (Q1-P) and determine the battery consumption when conducting (Q1-N and Q1-P). In fact, depending on the circuit used not even a resistor between G and S for Q1-P is necessary (or between the base and emitter the case of a bipolar transistor). This is true when using well defined voltages levels on gate-source. See figure below, for alternatives:
Power Control
