I am using an STM32 microcontroller.
If I configure a pin as input with a pull-down resistor for use with a button, do I also need to put a resistor between the input pin and VDD?
No, you put the button between the input pin and VDD. Putting a resistor will simply create a way for electricity to flow from VDD to VSS, using up power needlessly.
