I have a problem connecting different modules in a top module. I want to do a very simple PWM using a counter and a comparator.
Counter:
module counter
#(parameter N = 6)
input wire clk,
input wire enable,
output wire [N-1:0] q
reg [N-1:0] r_reg=0, r_next=0;
always @(posedge clk) begin
r_reg <= r_next;
end
always @(*) begin
if (enable)
r_next = r_reg +1;
else
r_next = r_reg;
end
assign q = r_reg;
endmodule
comparator:
module pwm
#(parameter N = 6)
input wire [N-1:0] cin,
output wire pwmsig
reg [N-1:0] threshold;
reg d = 0;
initial threshold = 6'b011111;
always @(*) begin
if (threshold > cin)
d = 1'b1;
else
d = 1'b0;
end
assign pwmsig = ~d;
endmodule
The modules work fine and if I put everything in one module it works as intended. But if I try to connect them in a top module:
module top
#(parameter N=6)
input wire clk, enable,
output wire pwmled
wire [N-1:0] connection;
counter cnt1(
.clk(clk),
.enable(enable),
.q(connection)
pwm pwm1(
.cin(connection),
.pwmsig(pwmled)
endmodule
I get an error message:
ERROR - Port 'clk' is unconnected. ERROR - Port 'enable' is unconnected.
RTL simulation works fine (I am only including the top module in my testbench). It just wont let me connect 'clk' and 'enable' to actual pins.
I am using Lattice Diamond 3.1.
Edit: I get the following Warnings in the Map Report:
WARNING - map: IO buffer missing for top level port ena...logic will be discarded. WARNING - map: IO buffer missing for top level port clk...logic will be discarded.
I ran the design through Quartus II and got working results... any Ideas where I am going wrong with Diamond?
