I wanted to know if it was possible to dynamically regulate voltage with, for example, a potentiometer which allows me to select output voltage and some kind of voltage regulator.
Suppose that I have a solar panel connected to this hypotethical voltage regulator; I want to be able to choose the output voltage of my regulator in 'real time' so that I can recharge for example batteries with different voltages.
Output voltage and voltage regulating are two different things. The second should be done by the regulator.
This is how you can achieve the first if you're using a LM317:
With digital outputs:
And the potentiometer variant:
  • \$\begingroup\$ Thanks for your response, I am studying your circuits since I am kind of new to this field \$\endgroup\$
    – Warrior
    May 23, 2014 at 15:52
I strongly suggest you use a switching converter, especially for charging batteries. The LM2596 is easy to use and cheap.
LM2596 circuit LM2596
