8
Can Anyone help me to identify this board to board connector? 7 springs connector on top and 8 on the bottom.
answer Found a Korean company producing it. Thanks.
This is the plug on the other end... enter image description here
Connector with Ruler for size reference.. enter image description here enter image description here
  • \$\begingroup\$ Might help if you stated where you got it from. \$\endgroup\$ – Funkyguy May 25 '14 at 3:41
  • \$\begingroup\$ I took it out from a Mazda modular cd player. It seems like all their plug in audio component uses them. \$\endgroup\$ – Percy May 25 '14 at 4:37
    \$\begingroup\$ Do you have a ruler (0.1mm or 0.010inch) to identify the dimensions, such as spacing between contacts along the bottom row? If it's 1mm pitch, maybe Hirose DF9-15 series of SMT plug/socket; ask samples from digikey.com: DF9-15P-1V(32) DF9-15S-1V(32) DF9B-15P-1V(32) DF9B-15S-1V(32). Looks like 15-pin, dual row; is it 1mm, 2.5mm, or 3mm pitch? Hard to tell without a size reference. And, any manufacturer logo stamped in the plastic body? (HRS=Hirose, S=Samtec, AMP, 3M, Molex, etc?) \$\endgroup\$ – MarkU May 25 '14 at 22:18
  • \$\begingroup\$ @MarkU Wow The Hirose actually looks really close. I have added 2 more screenshot with a ruler as reference. I have also try to look for any form of marking on the connector, but it is clean. \$\endgroup\$ – Percy May 26 '14 at 6:53
  • \$\begingroup\$ Small side note: if this is from a car, it is very likely either a customer-specific SKU which passes their specs instead of something available on the free market. \$\endgroup\$ – user36129 May 26 '14 at 9:11
I think it may be a Molex board-to-board connector but I'm confused about its actual name. The best way may be to ask Molex tech support.
