I want to read my meter at home with an Arduino board. My meter, an Itron C1S, has an IR emitter that pulses once (10ms width) every Wh.
I want to know if it is theoretically possible to use a normal photoresistor to read this values. If yes, how can I specify the photoresistor? If not, what would be the alternative?
Theoretically, yes.
By choosing one that is sensitive to the IR wavelength range. Which most common ones are not. As seen in this datasheet, photoresistors tend to peak at 650nm, right in the middle of the visible light range.
So you need something that is sensitive to the IR wavelength range. 900 - 1300nm is typical. What you want is a IR Phototransistor.
