Some relay cores are represented by two parallel lines and others by three. Does the number of parallel lines have any significance?
Saw this symbol in Tiny cad. What does three parallel lines in the picture imply?
  • 4
    \$\begingroup\$ A picture would help. \$\endgroup\$ – Andy aka May 29 '14 at 8:44
  • \$\begingroup\$ Here is some indication g3npf.co.uk/inductors.htm. It's for inductors though. But no standards mentioned. \$\endgroup\$ – Sohail May 29 '14 at 8:54
  • \$\begingroup\$ Number of lines has no significance - artistic freedom prevails in most cases. \$\endgroup\$ – Russell McMahon May 29 '14 at 13:43
It would indicate an inductor (the coil) wound around an iron core (as opposed to no lines indicating an air-wound inductor).
    \$\begingroup\$ And the number of lines only says how many lines the designer of the relay symbol thought looked good. \$\endgroup\$ – WhatRoughBeast May 29 '14 at 11:19
