I have a dead PSU. I opened it up, and I found three bulging 1000 µF general purpose-type crappy electrolytic capacitors. I've replaced capacitors like this on several motherboards in the past, so this will be fairly trivial to do, but the only capacitors I have handy are low-ESR types. Could a swap like this work out, or should I grab a few general-purpose capacitors from a supplier?
6
Generally, low ESR can be used to replace general purpose capacitors, but there are situations where the low ESR capacitor could cause oscillation due to the use of a finicky regulator.
For example, the LM1117 is a very common semi-LDO regulator (mostly because it's cheap and you can get them very easily).
It has requirements as follows (from the datasheet):
The ESR of the output capacitor should range between 0.3Ω - 22Ω
A lot of low-ESR 1000uF parts are better than that (by more than 10:1 in some cases).
You could always add a series resistor to degrade the low ESR parts.
  • \$\begingroup\$ This is for a PSU for a PC, and a cheap, generic PSU at that. Would that make a difference? \$\endgroup\$ Commented May 30, 2014 at 21:02
    \$\begingroup\$ If it's for a PC, I'd guess they're already low-ESR, just no-name ones made with the infamous counterfeit electrolyte. \$\endgroup\$ Commented May 30, 2014 at 21:07
    \$\begingroup\$ They're Fuhjyyu TN series general purpose caps (a known bad capacitor). The PSU they're in is probably 6-7 years old. They do make a low ESR series, but these aren't it. \$\endgroup\$ Commented May 30, 2014 at 21:52
  • \$\begingroup\$ I'd bet you'd be okay with the low ESR types. \$\endgroup\$ Commented May 30, 2014 at 21:53
  • \$\begingroup\$ Ok, will physical size matter? The low ESR caps are smaller than the GP caps, though they're rated the same (1000uf 10V 105C). \$\endgroup\$ Commented May 30, 2014 at 22:20
I'm not saying it is the case in your power supply but some switching regulators rely on the non-zero (or low) ESR of the smoothing capacitor(s) to produce a distinct ripple voltage at the output. This ripple voltage is fundamental to how some switching regulators work. I'm thinking of the Texas Instruments LM5009 - it requires some series resistance with the smoothing cap for it to work properly because it is of the "constant-on" topology: -
High power SMPS usually benefit from the lowest ESR capacitors, as currents are high enough to provide 50mV sense current feedback (or feed-forward) from a shunt.
Small SMPS can be quite unstable with extremely low or high ESR as there is not enough voltage ripple from wide control range current feedback if no minimum load is specified. Datasheets will specify.
So I would hazard a guess that high ESR and thermal fatigue caused these failures from use of GP caps.
You can observe regulation with no load or nominal load for verification. 10% minimum pre-load is common on PC PSU 5V only.
