How to find the voltage labeled v(x) by Nodal Analysis?
The sum of currents from node 2 to node 0 is equal to 0. However, I do not know the the current of 0.1Vx. How to solve the question?
Thank you for your help.
Since it is voltage controlled current source, the current from node 0 to 2 is 0.1Vx. Here replace Vx = V2-V3. So the last equation is :
$$ (V_2-V_1)/2 + (V_2-V_3)/4 - 0.1V_x =0 $$ $$ =>(V_2-V_1)/2 + (V_2-V_3)/4 - 0.1(V_2-V_3)=0 $$
Solving this equation, you would get V2, since V1=50V & V3 =100V
  • \$\begingroup\$ 0.1Vx is a current instead of a voltage? \$\endgroup\$
    – Casper
    May 31, 2014 at 6:22
  • \$\begingroup\$ yup.It is a dependent current source, whose value is dependent on voltage Vx. Search with "voltage controlled current source" for more details. \$\endgroup\$
    – hassansin
    May 31, 2014 at 6:26
  • \$\begingroup\$ So the answer should be V2 = 61.54V and Vx = -38.46V. Right? Are there any other methods for me to check the real answer by myself? \$\endgroup\$
    – Casper
    May 31, 2014 at 12:10
  • \$\begingroup\$ There are other techniques like mesh analysis, superposition theorem. You can apply them and verify your answer. By normal inspection you can also tell if the values make any sense. \$\endgroup\$
    – hassansin
    May 31, 2014 at 13:25
