I am trying to learn more about what I believe is called 'flex copper' ribbon cable. This is the cable that you often see connecting CD drives to main boards in laptops etc. where the cable 'curls' back when the drive moves. Similar to FCP and or FFC but made of a flat copper like material.
Is this called 'flex copper'? Does anyone have resources for custom manufacture?
What you're talking about is a flex(ible) circuit. They are often made by different factories from rigid board, perhaps with the same corporate name.
They are available with various numbers of layers, thicknesses of copper, features such as stiffeners and finishes and other options. Often they use orange polyimide (Kapton is one trade name) for the polymer substrate.
Shopping recommendations are off-topic, but you can find many sources for flex circuits. You use more-or-less the same CAE tools to design them, but NRE costs tend to be higher. Prototyping thus tends to be expensive.
    \$\begingroup\$ The google-friendly keyword should be FPC \$\endgroup\$ Commented Jun 2, 2014 at 21:56
  • \$\begingroup\$ Or FFC - Flat Flexible Cable, Or Flex Circuit \$\endgroup\$ Commented Jun 3, 2014 at 5:06
