I am building a food cooler for camping this summer. My plan is to build a thermoelectric cooler that is solar powered. My cooler is looking much like this:
Cooler diagram
including a CPU fan on the hot side and heat sink on the cool side.
I bought a 5W, 12V solar panel to run it (and make it so I can also plug it into my car). Both the fan and the TEC will be connected in parallel to the source.
Because the source is driving two things, are there any special considerations I need to think about such as a diode on the TEC so that when it loses power it doesn't dump heat back into the cooler by powering the fan? Or do I want it do run the fan after it loses power to remove heat from the hot side to reduce the differential faster?
  • \$\begingroup\$ 1st consideration is the laws of physics - a 5W cooler is not going to keep very much very cool compared to the ambient heat energy / power of the sun beating down. I have a good quality compressor-powered 12v fridge that can keep a couple of six-packs cool but on a hot day it's drawing on average more like 25-50W. \$\endgroup\$
    – John U
    Jun 4, 2014 at 18:55
  • \$\begingroup\$ I do plan to keep the cooler itself in the shade. I just got it going and am testing the cooling now. \$\endgroup\$
    – traisjames
    Jun 4, 2014 at 19:05
  • \$\begingroup\$ Just make sure you don't shade your photovoltaic panel!! Maybe consider making this cooler smaller or adding more heat pumping capacity. \$\endgroup\$
    – HL-SDK
    Jun 4, 2014 at 21:30
  • \$\begingroup\$ I had the panel kind of in the sun today and it dropped about 5° in the hour it had sun. I do need to fill in the holes I made to keep the cool in actually have the solar panel pointed towards the sun and not behind a screen window. \$\endgroup\$
    – traisjames
    Jun 5, 2014 at 1:08
  • \$\begingroup\$ Will TEC drive fan? Will TEC cool water X degrees in 4 hours given Y volts? 2 $3 temperature meters with remote probes could be used to display heat sink temperatures in & out. A $10 DMM can display voltage & current in & out of TEC while cooling or while heating. You could put ice in cooler, then record voltage output by TEC into fan. Getting actual performance data is not hard. Fine project for learning or teaching, not for keeping cool. \$\endgroup\$
    – user80735
    Jul 10, 2015 at 12:14
A diode will do very little harm - but probably not much good either. I'd put the diode in the fan side so that you get max possible power to the TEC.
5 Watts is unlikely to give much cooling at all. Maximum possible attention to insulation is needed. You can get more cooling initially with evaporative cooling and using this as well as the Peltier would help.
I read that to mean that with all external power removed the TEC will act as a TEG using the cool to external temperature differential.
A standard consumer grade Peltier does not make a good TEG (Thermoelectric generator) and even a purpose built TEG is not vastly better. The thermal differential is small compared to what you need to run the TEG on to get useful power. I'd be surprised (it happens) if you could run any sensible sized fan on the delta temperature between cold box and ambient. However, a TEG shunts most of its energy input to the cold side by conduction, which is the main reason for their poor efficiencies. (Much research is being directed at reducing electrical resistance and increasing thermal conductivity.)
The following is probably true but needs some thought:
A hot heatsink will allow heat to flow to the interior via a turned off TEC much better than the TEC can remove heat energy when operating. As the heatsink has been heated by both TEC thermal transfer AND electrical wasted energy you may be worse off if you run this for a while and then turn it off with a hot heatsink. So, if PV output starts to fall (eg end of day) you may be advised to divert energy to the fan to get the heatsink temperature down before power fails fully.
A low forward voltage-drop diode driving the TEC would be good to add to prevent it running backwards trying to drive the fan.
If it generates power to drive the fan, it will consume 95% of the energy (heat) and only drive the fan with that other 5%. In short, you'll loose a lot if it is allowed to run backwards.
