I'm trying to view my gerbers generated from eagle (using SparkFun's CAM file) as I and cannot get the drill file to import correctly for some reason.
When I drag the files into ViewMate, I choose 0.1mils as the unit of measure for the .dri file and inches for the .gpi file. This is the result:
As you can see, the scale of the holes is messed up.
Here are the Eagle and gerber files.
What am I doing wrong? How do I get it to display correctly?
I have run into this exact problem myself. The issue is that Eagle is playing a bit "fast and loose" with the formatting of the drill coordinates, and this causes Viewmate to infer the incorrect scaling. I messed around for a while before I finally wrote a short Perl script that reads in the Eagle file and writes a fresh one with a fixed number of digits for the coordinate values, which Viewmate reads correctly.
Unfortunately, that script is on a different machine, and it will be several days before I have access to that machine again. When I do, I'll add the script here. In the meantime, maybe this is enough of a clue to get you unstuck.
  • \$\begingroup\$ It really seems like there would have to be a setting in ViewMate or Eagle to get this working. Using a Perl script to modify a drill file seems a little extreme! :-) \$\endgroup\$
    – Nate
    Jun 6, 2014 at 13:17
  • \$\begingroup\$ @Nate: Yeah, you would think so, but I played around with both programs for a while, trying to find a combination of settings that worked consistently, and finally gave up. \$\endgroup\$
    – Dave Tweed
    Jun 6, 2014 at 16:41
