7
I work in possibly gas filled environments. As such safety recommendations are that I don't use my cell phone, camera and computer while touring around these areas that explosive gas may be present.
My job contains elements where using some digital devices is would be absolutely beneficial that aren't available from a vendor. For example, (I am not aware of) a device that can detect wireless router signals that is also intrinsically safe.
I wish to design such a device (or another), but I don't know what makes a device intrinsically safe at which lower voltage and the amount of space between components and such.
Is there a standard or a guideline or formula that defines this?
Edit: There are cell phone devices on the market that are rated intrinsically safe such as: M-Safe 28 or the Atex Advantage 1.0. I am thinking they aren't perfect but near perfect.
  • \$\begingroup\$ Could you not place your electronics in, say, a zip-lock bag to keep the explosive gases out? Any hermetically sealed bag would seem to do the trick. \$\endgroup\$
    – Samuel
    Jun 5 '14 at 2:58
8
This is based on UK/European practices: -
Firstly you need to decide what category zone and group you are likely to be working in. From memory Zone 0 is the most onerous and again, from memory, only Ex i (intrinsically safe) equipment is allowed. More than likely you are in group 2 because group 1 is reserved for mining environments.
I think these days you need to base things on the ATEX directive (94/9/EC) and it refers to Categories instead of zones, category 1 being the most onerous and requiring the greatest methods of protection.
There is also a very good guide from MTL on intrinsic safety that can be found here. I'd also take a look at this wall chart too - it contains some really good info like this: -
There is also MTL's Flammable facts poster that I remember referring to when designing Ex i equipment and contains such gems as this: -
Good luck.
Intrinsic safety is one approach to assuring safety (limiting the energy the device can possibly release to guarantee no ignition for a specific class of hazard). Intrinsic safety limits can be exceeded by the presence of a small capacitor, long wires etc. That can be extremely restrictive in terms of what is permitted, but it can allow wiring from non-intrinsically safe devices such as computers to sensors placed in hazardous areas to be placed in the open, provided they are passed through an approved (for the class of hazard) intrinsic safety barrier- a very reliable redundant terminal strip block type of device that will never let dangerous energy through, so unless the devices on the other side of the barrier do something prohibited like store more than a tiny amount of energy they are intrinsically safe. A practical example of this might be a thermocouple connected through a barrier to a computer in a control room. Even if the computer fails and puts 240VAC on the thermocouple inputs relative to ground, the barrier will prevent that from getting to the hazardous location (methods used are redundant Zeners, fuses, series impedance etc.)
Another approach is to put the device into an approved ( for the type of hazard ) explosion-proof housing. Such a housing is designed to not rupture if the gas inside explodes (to contain the explosion), and to only release gases that are sufficiently cooled so that it will not act as an ignition source itself.
Another approach is to put the device in a housing that is maintained constantly at a positive pressure with a purge air inlet, and that condition is continuously monitored.
There are established IEC 60079 and CSA 22.2 etc. classes for different types of hazardous gases and powder explosion hazards (acetylene and hydrogen are worst, IIRC, and ordinary baking flour can explode). Find out what class, category, division, zone etc. you must conform to and comply 100% with the requirements using only approved devices (or 'simple' things like RTDs or thermocouples) to guarantee safety, as determined by a licensed Professional Engineer who is willing to sign off on the choices. It's way too expensive to get approvals for a one-off, so the housing method may have to be used if you can't find rated devices.
It sound like you might be in Zone 2 where occasional flammable gases may occur a few times a year as opposed to Zone 1 where it is highly likely this to occur many times a year. As far as Zone 0, I only know of actual gas sensors etc that are certified for this type of work.
The 60079-11 standard deals with setting these guidelines for electronics design from concept to PCB design, and there is also the other aspect of the housing which adds the hermetic sealing level of the product. If this you can get to IP67 or IP68 then you will be able to mitigate the rest of the security issue with intrinsic safety by following and certifying the final product electronics to 60079-11.
Unfortunately as somebody mentioned, you cannot just place the equipment in a plastic bag, as the plastic may cause static sparks in the right circumstances and this would be a no, no in any Atex zone.
Essentially protective covers and housing are also subject to design guidelines as set out by the ensemble of the 60079 standards. There may be ATEX certified plastic pouches out there but do you wanna fork out 300 bucks for one and find out it makes product use not very functional ?
