Which IC can I use to control 7-segment display? I want to make simple projects like a reaction timer but I don't have an Arduino or some other microcontroller available. What ICs can I use instead?
closed as too broad by Andy aka, Leon Heller, placeholder, Matt Young, Stephen Collings Jun 5 '14 at 14:31
Please edit the question to limit it to a specific problem with enough detail to identify an adequate answer. Avoid asking multiple distinct questions at once. See the How to Ask page for help clarifying this question. If this question can be reworded to fit the rules in the help center, please edit the question.
  • \$\begingroup\$ There are thousands of ICs that can drive (or control) a 7 segment display but this is too many to list. \$\endgroup\$ – Andy aka Jun 5 '14 at 12:56
  • \$\begingroup\$ suggestion:7447. \$\endgroup\$ – nidhin Jun 5 '14 at 12:58
  • \$\begingroup\$ There's also the CD4511, that can be used to drive common-cathode displays. The 74LS'47 and 74LS'247 are used to control common-anode displays. That's an important distinction by the way: you need to know whether you have a CA or CC display. If you didn't order them yet, you need to pair them with the right driver. \$\endgroup\$ – Ricardo Jun 5 '14 at 13:01
  • \$\begingroup\$ Here's a few links that may help you learn how to use 7-segment displays. \$\endgroup\$ – Ricardo Jun 5 '14 at 13:05
  • \$\begingroup\$ This article seems to be a good one to start with: The 7-segment Display. It talks about common-cathode and common-anode configuration and how to drive the display with CD4511. \$\endgroup\$ – Ricardo Jun 5 '14 at 13:06
Assuming you are talking about LED 7 segment displays (as opposed to LCDs), you could use the '47 or '247 devices from the 7400 logic family, e.g. 7447.
In addition to @fmunkert
If you're talking about 7-segment LCD, you could use CD4054/4055/4056 CMOS chips.
