I am trying to do a project where I am getting two (or more) voltages and averaging them all out. Then I would like to use a trimmer pot to adjust the voltage by a percentage, basically as a fine-tuning calibrator.
The elements I am using are 2 or more humidity sensors, They take a voltage in (5.5v) and give a voltage out (a percentage dependent on the humidity). I will average those voltages out and want to have a relay switch when the voltage reaches a certain number.
I am new to this, so I assume if I get a 5v DC relay (OUAZ-SS-105D) I will need 5 volts to switch the relay over. The humidity sensors will only output around 3-4 volts averaged. I would like the relay to switch over when the average voltage output from the humidity sensors reaches 4.125v.
How should I approach this? Does this make sense? or did I totally confuse you?
