So I have been looking at building a circuit for a water-powered motor that I have been trying to develop.
I plan on starting off with this battery. Then I will hook it up to this high voltage transformer.
After that, I need to do something in particular with it, I need the output to look sort of like AC in the sense that the current switches directions. Let me explain the purpose and the planned additions that I will need to make it happen.
I am trying a concept of a water cell where the water serves essentially as a dielectric in a capacitor. Don't worry about why or how, what makes it happen, but take for granted that I will need relatively high frequency and high voltage AC going through there, or DC pulsed. Now, the point is not to break down the water at this stage, so what I want is simply high voltage positive and negative pulses on the two plates of the "water capacitor" going back and forth as in AC current. I said that the point is not to break down the water, at least not at this stage: that means that current will not "break-through" the dielectric, but the pulses of the electric field, in the form of the potential, or high voltage will constantly change the electric charge of the plates (of the "water capacitor").
So, the high voltage transformer was made to make arcs, and as such does not allow output shorting or a no-load situation. I want that transformer to connect to the water capacitor. Now, a capacitor is a load, but not always, if I understand correctly, and I don't want the pressure to destroy the transformer. As such, right after the transformer before the water capacitor, I was considering adding this resistor
Well, I did some calculations on what the transformer might draw, and I will be using at max 18 watts of power, it just depends on what the high voltage transformer draws.
3V : 6 Watts : 2 Amps
4V : 8 Watts : 2 Amps
3V : 13.5 Watts : 4.5 Amps
4V : 18 Watts : 4.5 Amps
As such, I wanted to have a load present so that undue stress was not put on the high voltage transformer, causing it to no longer function properly, if at all. That load would be the resistor. I did a little extra so that it didn't burn up, and I allowed for the Ohms not to be too high, because I want the high voltage present for the pulses.
Now, there are a few things that bother me about the circuit so far. The high voltage transformer works sort of like an ignition coil from what I understand, but it builds up voltage until it can arc, and does arc. So I feel like that is a steady build-up, and that is ok, and it is not supposed to short to the input of the circuit, so that is even better, however, how would I get that switch of direction present in AC with the present set-up?
Present set-up:
Battery(4V 4.5Ah)----[DC, constant flow of this]
High Voltage Generator(20kV 0.9mA (max))----[quick constant electric pressure as output]
Resistor(25Ω 20W)----[max 112.5V loss, still at least 19kV for sure even with other losses]
Water Capacitor(charging, uncharging cycle for each plate, but no breakdown)
That is it for the set-up. If anyone has improvements that they would like to suggest on my design so far or errors to point out (but please read until the end before you do), feel free to, as well as if anyone can find a high voltage transformer that can get like 3V with no minimum wattage and just milliamps to at least 20kV, that would be great. However, my real questions come now.
If you noticed, the high voltage transformer in the current set-up charges, but has no way of releasing as the water capacitor doesn't have a point where current flows through it, only the pressure build-up. So, I was thinking of a switch before the transformer, looking into different kinds, probably a transistor, because of the wear and speed and automatic factors in consideration. Problem: I don't have any idea how to make one work with a battery and need an automatic switch, preferably not using up a lot of power or requiring a ton of parts. I need help with this.
Also, to go with the switch, I was considering hooking up a normal capacitor after the water capacitor to gain power and, when the switch turns the transformer off, to allow for the flow of electricity to power the other plate of the water capacitor, switching the charge, and create the AC like effect. I have no idea if or how that would work. My thought process is that it will probably charge the second capacitor as well, because it won't be able to get anywhere with the first one. However, how would it charge the second capacitor and if it does, would it be charged with a high voltage low amperage combination or change things a bit to deal with it? Also, I was kind of wondering about the flyback voltage from the second capacitor discharge, and if I would need anything to stop it, outside of the first capacitor, which should absorb it, as the current has switched directions from the perspective of the water capacitor, and the resistor.
As such, this is my current picture of the circuit.Current Circuit Plan
So, as you can see, I have a problem with the switch and with the secondary effect which is so crucial to creating a certain environment inside the water capacitor. Thank you for any help that anyone here can give. I still have much to learn, so please point out any mistakes and I welcome any safety concerns or tips that you might have to give. As I said, I have much to learn and am glad to learn it. Thank you again. I hope you all have a good day.
    \$\begingroup\$ It would be better if you could present a schematic of your setup rather than explaining it in words. \$\endgroup\$
    – nidhin
    Jun 7, 2014 at 5:50
    \$\begingroup\$ What precisely is a "water powered motor"? Is it one of these upload.wikimedia.org/wikipedia/en/thumb/c/c5/… \$\endgroup\$
    Jun 7, 2014 at 10:16
  • \$\begingroup\$ How big is one of your water capacitors going to be? If it's a 1 cm cube or larger, your power supply is not adequate. \$\endgroup\$ Jun 7, 2014 at 16:42
  • \$\begingroup\$ Alright, edited it. I included a picture of what I am trying to say. A water-powered motor is a motor that takes normal H2O and turns it to H2 and O2. That's slightly irrelevant to the circuit building, but so you know. And all I need the power supply for, is not for current, but for the change of the electric field at high voltage levels. As such, although each prototype capacitor is 4" x 1", I won't have any problems with it. \$\endgroup\$
    – Enominos7
    Jun 8, 2014 at 0:15
    \$\begingroup\$ Sorry, it is a cylindrical capacitor and the outside diameter is 1" with the length being 4." Although it does seem sort of like an electrolysis unit or an electrolyzer, it is a completely different process. The water molecule will not be split apart using current, so calling it either of them would be misleading. Also, I have built water capacitor myself. I could get you more exact dimensions and the layout, but there would be no purpose in it. The current would not pass through anyways because of a coating I have put on the plates and the purified deionized water that I will be using. \$\endgroup\$
    – Enominos7
    Jun 8, 2014 at 20:22
Where to start?
First, your HV unit is not a transformer. It is a high-voltage module. It puts out a pulsing high voltage.
So, the high voltage transformer was made to make arcs, and as such does not allow ... a no-load situation.
You are correct. Your capacitor will store charge and will destroy your module. Furthermore, you have taken the input power specification, (and it would be nice if you would share with us where you got the numbers) of 18 watts at 4.5 volts, and then calculated an output power of 18 watts/20 kv, giving .9 mA. This is wrong. Input power does not equal output power.
You have also failed to notice the part of the description that reads
Work: Input voltage 1.5V ~ 3V can work for about 1 minute, the input voltage exceeds 3V continuous work does not allow more than 30 seconds
In other words, you will not be able to run your unit for more than 30 seconds at a time. And it doesn't say how long you need to let the unit recover from 30 seconds operation, either.
Having failed to understand your HV unit, you have equally failed to understand your water capacitor. To begin with, ultrapure water is does not have an infinite resistivity. It is, in fact, 18 Mohm-cm. For your described capacitor, this amounts to ~ 2 Mohm. At 20 kV, that will require 10 mA which you cannot provide. You mention a "coating on the plates" which you believe will prevent current flow, but you do not describe it, and I hope you will forgive my suspicion that it may not work as you plan.
You speak of your desire not to break down the dielectric (the water) and then talk about how pulsing or AC voltages will avoid this. You seem to be unaware that the breakdown potential for pure water is ~3 MV/m. Since the spacing for your capacitor is on the order of 12.5 mm, the breakdown voltage will be ~ 37 kV, or twice your voltage, and you have no need to worry.
Given the dielectric constant of water (80), the effective capacitance of your capacitor will be ~ 100 pF. Since your module has a diode in its output, you are correct in thinking that you will get just a DC output, since there is no major discharge path. You cannot discharge your capacitor from the input side. Any such discharge mechanism would have to be synchronized with the HV pulses, and would have to withstand 20 kV. Such a circuit will be neither simple nor cheap.
Your selection of series resistor is very strange. Your calculation for voltage drop make it clear that you have used the input figure of 4.5 amps, and this has absolutely no application to the output.
So, overall, I have no way give you advice, except to suggest that you do something else. I don't see any instance where you seem to actually understand how your proposed circuit would work, or why, and that is not a good starting point.
  • \$\begingroup\$ As a bonus, if you are able to prevent leakage currents, the module will destroy itself. It says you must limit the output voltage by virtue of having a certain size arc present. \$\endgroup\$
    – gbarry
    Jun 9, 2014 at 2:49
  • \$\begingroup\$ Aha. Nice catch. I thought I'd dealt with that with "may well destroy your module". Oh well, that's what edits are for. It is now "will destroy". \$\endgroup\$ Jun 9, 2014 at 2:58
  • \$\begingroup\$ I used the term "transformer," because it was the best term I knew for something that steps up voltage. I got the numbers from the module page, looking at the max that it would draw. Yes, there are losses, but I don't know what those are yet. I dealt with those where I said 19 kV. I also know the time limitations: this is just a proof of concept prototype. Obviously the water is the main thing stopping the current in the capacitor. The coating was to serve as an extra dielectric though to reverse the polarity and include a necessary material in the process. The pulsing or AC voltages will... \$\endgroup\$
    – Enominos7
    Jun 10, 2014 at 18:33
  • \$\begingroup\$ not cause this, but they will also not be why that is avoided. There is no capacitor on the input side, so I'm not quite sure what you are trying to say there? I chose it to prepare to the maximum wattage that might go through it, making sure it was more than was needed. I hope you now understand my circuit better. Anyways, I love the confidence. ;) I hope that now you might be able to address the switching problem and whether or not I should use another capacitor on the output side. Also, I will probably ground on the output side before the water capacitor on the lower line. Also, please... \$\endgroup\$
    – Enominos7
  • \$\begingroup\$ let me know if there is anything else that I can clarify! \$\endgroup\$
    – Enominos7
    Jun 10, 2014 at 18:34
