9
I am designing a keypad in VHDL. Everything works fine when only a single key is pressed. I'm scanning each column for a key press in a state machine and when no key is pressed, which is the condition pin4pin6pin7pin2 = "0000" I switch to next state for scanning the next column. Thus I set the columns pin3pin1pin5 sequentially to "001", "010" and "100".
While scanning pin3pin1pin5 as "001" and if pin4pin6pin7pin2 is "0100" then simply "9" is pressed. I declare in VHDL pin4pin6pin7pin2 as input and pin3pin1pin5 as output ports. When I press 6 and 9 at the same time pin6 and pin7 are high. The first pressed key is read, the second one is ignored. When I press 3 and 7 at the same time, the first one pressed with few ms before wins and the first key is read, the second key is ignored, pin2 and pin4 are high.
Here is the tricky part. When I press 4 and 6 at the same time, I expect pin7 to be high but it becomes low and pin4pin6pin7pin2 = "0000", which I don't understand how and why. Because "0000" is detected as a no key pressed, the state machine jumps from state to state. While holding 4 and 6 if one pushes and leaves 4 several times, it is detected as 6 pressed several times, which is a big bug. I would be glad if you can help me debug this!
Same thing happens with "1" and "2", same with "7" and "8" only for the keys on the same row. Since this is an ongoing project I can't put my VHDL code online :( I would be glad if you can give me tips to overcome this!
Below, Im not uploading my code to the board, no code is running. Connecting Pin5 to ground, a single press on 1,2,4,5,7,8,*,0 does not turn Pin3 LED on but if Im pressing 6 and then 4 at the same time Pin3 LED is on and Pin7 LED is still on, but when my code is running this doesn't happen. Maybe I connected something wrong and luckily Pin7 is on, I don't know...
Below is the schematics of the keypad board:
Schematics
  • \$\begingroup\$ How are you ensuring that pressing 4 and 6 at the same time doesn't short pins 3 and 5 together? \$\endgroup\$
    – fru1tbat
    Jun 11, 2014 at 17:48
  • \$\begingroup\$ @fru1tbat Can you elaborate short a little bit more? Without uploading my code when the board has nothing on, I connect pin5 to the ground, then pin5 LED is on then I press "6" pin7 LED is ON later I press "4" and "6" at the same time this time pin3 LED is on and pin7 LED is still ON. \$\endgroup\$
    – Anarkie
    Jun 11, 2014 at 17:56
  • \$\begingroup\$ @Tut you mean I should use pull-up for rows and pull up for columns? I can't modify the circuit. Also didn't understand much from your comment :( \$\endgroup\$
    – Anarkie
    Jun 11, 2014 at 21:01
  • \$\begingroup\$ To be more complete, I'll provide an answer. It would be helpful if you could provide a schematic showing resistors, LEDs, column drivers and any inverters or transistors that may be in the circuit. Are the 4 rows and 3 columns connected directly to a CPLD or FPGA? \$\endgroup\$
    – Tut
    Jun 12, 2014 at 10:19
  • \$\begingroup\$ @Tut The keypad isn't directly connected to the FPGA there is another board in between, for connecting various boards to the FPGA and I added the schematics. \$\endgroup\$
    – Anarkie
    Jun 12, 2014 at 13:08
The short answer:
Invert your logic. Drive the column select lines with open-drain (or open-collector) logic where the selected column is pulled low and the un-selected columns are floating. When you look at a row, a key-press will be detected by a '0'. Un-pressed keys will be detected by a '1'.
Now the details:
As EEIngenuity points out, when you press 2 buttons in the same row, it results in a short-circuit between their corresponding columns. This (and other problems involving multiple key presses) is usually overcome in a keyboard matrix by adding a diode in series with each switch.
Since adding diodes is not an option for you, you will need to float the outputs of your inactive column selects to avoid trying to drive them to the opposite polarity as your active column select. This is done using open-drain logic. If your column selects are tied directly to a CPLD or FPGA, you should be able to accomplish this in your VHDL code.
The photo in your question shows that you have a pull-up resistor on each column and each row. The pull-ups on the columns are unnecessary, but will not hurt anything. The pull-ups on each row will assure a high condition unless pulled low by the open-drain driver on the column selects (through a closed switch).
I have had to make some assumptions about your circuit since you have not provided a complete schematic or your VHDL code. You say
yet from the photo you provide, pull-up resistors are shown. This implies that you already have a logic inversion somewhere, possibly in your VHDL code or (less likely) inverters between your rows and your logic device (CPLD or FPGA).
Edit:
Per your comment, you are using negative logic in your descriptions: "0000" indicates all four pins are high, etc. That being the case, assuming the column selects and row signals go directly from connector 2 on your schematic to the FPGA, just follow my directions above by using open-drain logic for the column select outputs in your FPGA.
I am not a VHDL expert, but I found this from Xilinx:
Infer the open drain buffer by using the following code:
VHDL:
dout <= 'Z' when din='1' else '0';
Also note in your schematic, all of the LEDs are shown wired backwards. The anodes go to the current-limiting resistors and the cathodes go to the signal lines. The LEDs light when the signal lines are pulled low.
  • \$\begingroup\$ I'm about to scan the schematics installing the scanner driver \$\endgroup\$
    – Anarkie
    Jun 12, 2014 at 11:27
  • \$\begingroup\$ You are right about pin4pin6pin7pin2 = "0000" no key press is actually 1111 . In my question 1s should 0, 0s should be 1s, I tried to crypt the question a little bit, sorry for that if it caused misunderstandings... \$\endgroup\$
    – Anarkie
    Jun 12, 2014 at 12:07
  • \$\begingroup\$ I added the schematics. \$\endgroup\$
    – Anarkie
    Jun 12, 2014 at 13:09
  • \$\begingroup\$ thanks a lot for your explanations, after reading your answer I have some ideas but first what do you mean with "columns are floating" , "need to float the outputs" , by float do you mean : 110, 101, 011 ? This I am doing already, actually in my code when a key is pressed all other keys should be ignored I just don't understand how the LED turns off and pin7 becomes high(1), while code is running. Anyway if I understood correct is your solution suggesting while Im scanning pin5, output ports "110", I should have out <= 'pin3' when din='1' else '0'; \$\endgroup\$
    – Anarkie
    Jun 12, 2014 at 15:38
    \$\begingroup\$ Look at the link I provided: open-drain (or open-collector). The active column is selected by driving 0V on that column line. The inactive columns should NOT be driven with 3.3V on that line, but need to be floated (put into a high impedance state) which effectively disconnects those lines from the circuit. If you try to drive them to 3.3V, the short-circuit created by pressing 2 buttons in the same row at the same time, will cause a contention between one trying to drive low and the others trying to drive high. \$\endgroup\$
    – Tut
    Jun 12, 2014 at 15:56
Since you are using VHDL and you have an asynchronous input, I'm writing this answer to ensure you took a precaution. I'm not sure if this is your issue but it very well could be.
See a question I asked some time ago: VHDL: receive module randomly fails when counting bits
Now, you say that:
Which is somewhat similar to what I was facing. I had an issue where my state machine would skip states, which seemed impossible.
If you read the answers to the question linked above, you'll see that it is recommended to add a synchronizer to the input line before it is fed into your state machine. This is typically accomplished with two D Flip Flops in series:
Not having your button input synced with your HW causes very bizarre issues, which I've experienced with my N64 project. Adding this little bit of HW was almost like magic.
So please check first that your inputs are being synced.
  • \$\begingroup\$ To implement the Synchronizer on the answer doesn't seem to be difficult but when I read the process, what I understand is that async_in is delayed with 3 clock cycles but its value and everything is the same? \$\endgroup\$
    – Anarkie
    Jun 11, 2014 at 18:48
  • \$\begingroup\$ The big difference is that your signal will be converted from asynchronous to synchronous. What happens in HW sometimes with asynchronous signals (like your buttons) is that the bits are in "meta-stability", this causes very strange errors in the HW. Using the D Flip Flops ensure that meta-stability does not occur in your design. I was also skeptical of the effectiveness of this, but it solved my issue perfectly. \$\endgroup\$ Jun 11, 2014 at 18:52
  • \$\begingroup\$ I tried it, was worth a try but didn't help :( \$\endgroup\$
    – Anarkie
    Jun 11, 2014 at 19:14
This is an interesting question! The reason you are seeing a low on pin7 when you press key4 and key6 is because of pin3 and pin5.
To explain further, pin3 and pin5 will never be high at the same time - one of them will always be a path to ground (according to your design). Thus, when you press key 4 and key 6, you are creating a path to ground for pin7.
See image:
Pin 7 sees a path to ground. You have a short circuit.
  • \$\begingroup\$ I added a picture to my question and pin7 looks high still when both keys are pressed. \$\endgroup\$
    – Anarkie
    Jun 11, 2014 at 18:22
  • \$\begingroup\$ OP explained that he does not raise pin 3, 1 or 5 HIGH at the same time at any moment. He sequences the columns with: "001", "010", and "100. Pins 3 and 5 are never HIGH simultaneously to begin with. \$\endgroup\$ Jun 11, 2014 at 18:22
    \$\begingroup\$ That's the point @EEIngenuity is trying to make - there's an apparent path between pins 3 and 5, which will never have the same value, "thus, when you press key 4 and key 6, you are creating a path to ground for pin7." \$\endgroup\$
    – fru1tbat
    Jun 11, 2014 at 19:38
    \$\begingroup\$ @Anarkie In the picture Pin3 is not connected to GND or VDD. It is a floating node. This does not create the short-circuit scenario that you have in your original trial. Try to connect pin 3 to VDD and Pin5 to GND and repeat this test. \$\endgroup\$ Jun 13, 2014 at 20:20
    \$\begingroup\$ @EEIngenuity You are absolutely right!!! Yes, yes when I connect pin3 to VDD, pin7 becomes low!!! So please help me how can I overcome this problem and make it work :( I'm using VHDL and also another colleague who is in the same project in a different team, doesn't face this problem so somehow he solved it but I don't know how, same keypad, same board! \$\endgroup\$
    – Anarkie
    Jun 14, 2014 at 12:36
