I need to mount a mini toggle or rocker switch to the outside surface of a box. For various reasons I cannot drill a hole, so the entire switch needs to be freestanding or glued to the surface. (There is a small hole for the wires to go into the box, but that's it.)
I remember seeing self-contained switches with nice plastic back covers, but I can't find any such components on the market. Can anyone recommend a good way to cover up the exposed contacts and even provide a nice flat surface?
  • \$\begingroup\$ How big is the hole for the wires? There are toggle switches that only require a 3/16 inch hole. \$\endgroup\$ – Barry Jun 11 '14 at 23:51
  • \$\begingroup\$ @Barry the position of the existing hole is not where I want to place the switch \$\endgroup\$ – Barry Rosenberg Jun 12 '14 at 1:09
Use heat-shrink tubing. Use a small size that will shrink to a snug fit on the wires and terminals, and a larger size to cover the body of the switch, and extend over the wires.
If the switch carries 120 or 240 VAC, I would prefer to add a box to contain the switch and wires, but the heat-shrink technique should be OK (not ideal) for low voltage.
| improve this answer | |
  • \$\begingroup\$ The switch will indeed be carrying 120 VAC, so it sounds like a box of some kind is a better idea. The trouble is finding something compact. \$\endgroup\$ – Barry Rosenberg Jun 12 '14 at 1:10
