It is said that a decoder with n input has 2n outputs corresponding to the 2n minterms of the n input variables. An n-to-2n decoder and m OR gates can, therefore, implement any combinational logic circuit.
Can anyone explain more detail about why, therefore, it can implement any combinational logic circuit?
This smells of homework, and anyway finding such things out for yourself is far better for you in the end, so I'll just give you a hint.
Draw the truth table of the n-input 1-output function that you want to make. The 2n outputs of your decoder correspond to the rows in your truth table. You want the result to be a 1 in the rows where you have put a one in the output column. Now how would you connect a many-input OR to achieve that? If have only let's say 2-input OR gates, how could you make an x-input OR?
I don't remember 100% of this as it was a long time ago but basically it's something like:
Decoders produce 2n minterms of n inputs, external or gates can be used to implement logical function in SOP form.
Steps: 1. Get the functions into canonical SOP form 2. Get a decoder with sufficient number of inputs for your functions 3. Insert external gates of proper size and start wiring according to the functions
Not a full answer but hope this helps a bit ...
