UDP will probably handle the data rate you need for audio streaming, but the latency will be problematic with live audio. Consider the path:
Source -> ADC -> I2C to UDP conversion -> Network -> Audio processing -> Audio output
I've had latency issues with audio when using analog wiring, professional digital interface equipment, and a high end computer. JACK and ALSA tend to be even less reliable, so I'm not sure what kind of performance you'll be able to get out of audio processing on a raspberry pi.
Most professional audio equipment I've used actually goes a different route that you may want to consider: rather than streaming audio to a computer, processing it, then streaming it back out, they have dedicated processing hardware that simply accepts control signals from a computer so there is virtually no latency added.
I think the "proper" way to do something like this would be to use a direct wireless connection (like Bluetooth, rather than relying on an external network) to stream raw audio data to an FPGA with some DSP utilities. The FPGA could be controlled with a Raspberry Pi or something similar through a SPI or I2C interface. There would be a lot more upfront work implementing the DSP algorithms for audio processing (rather than just using JACK plugins on a computer) but it would significantly reduce the latency in the processing stage. Using Bluetooth would also reduce latency in the transmission and reception stages, because it doesn't rely on a (possibly nonexistant, if you intend to make this system mobile) uncontrolled network.
That being said, I think that how you should actually implement something like this depends on precisely what you intend to do with it. Personally, I've wanted to build something like this for a while to simplify setup and teardown for live shows. My current solution is basically to replace the cables with some wireless replacement, and use commercial equipment for all of the processing. High quality mixers are pretty cheap (I also already own a few) and can't really be matched by ad-hoc solutions in terms of sound quality.
The thing that has held me back is the cost. This is the cheapest option I could come up with, and it requires the most upfront work: an ADC capable of audio conversion costs ~20$, a pair of bluetooth chips costs ~10$, and a pair of FPGAs for controls costs ~30$. That's mostly manufacturer spec parts; getting hobbyist equivalents would cost well over 100$, and that's just to replace one 10$ cable!
Back to your project, that's why you don't see wireless audio for instruments; it's prohibitively expensive to get the sound quality needed for making music (most of the common systems are for speaking only, so quality isn't nearly as important). Some purely wireless systems do exist, but they generally cost thousands of dollars, have dedicated hardware for transmission, reception, and processing, and generally use proprietary codecs and protocols.
If you still want to do your custom solution, look into JACK's audio streaming utilities. If you can figure out how to transmit with that protocol, you could plug your signal directly into all of the JACK extensions. You could then just download a JACK mixer to handle all of the processing an output.
