The Beddit sleep-tracking device (Beddit and @indiegogo) has a pressure sensor that looks like a thin (~0.3mm?), flexible tape about 2ft long. The tape seems to be constructed of several layers internally. If bent and pressed flat it seems to form permanent wrinkles, but still functions about the same. It has a two-pin electrical connector at the end. The sensor is usually placed under a person lying on a bed (0.2-0.5 psi pressure) but can detect tiny, fast variations in pressure/force (best guess from device performance: << 0.001 psi with > 20Hz bandwidth).
Can anyone identify what type of sensor that is? How can I try to test it? Where can I get one like it?
