16
I always assumed that the shape of the antennas was important; a vertical monopole for pitch and a horizontal loop for volume, thinking that this minimized their interference with each other. But it seems they actually operate more in the range of 200-500 kHz. At these frequencies a good antenna would be hundreds of meters long, and the use of different frequencies for each antenna is sufficient to prevent interference.
On the other hand, the Moog Etherwave schematic has a bunch of coils in series with the antennas, which could be electrical lengthening?
Most descriptions I've read explain that it's just the human's capacitance to ground that detunes the oscillators, so any shape of metal will do, since it's just acting as a capacitor plate.
This page describes something different, though, which I don't understand:
Beyond 4 inches (10cm) RF heterodyne theremin pitch variations are caused from changes in the "radiation resistance". This is the total RF electro-magnetic power radiated from the pitch antenna divided by the square of the net current flowing into the pitch antenna. The pitch field is a dual electrical/magnetic equilibrium, not just a capacitive field as so commonly state.
Some more explanation here
Is this correct? What's wrong with the capacitance explanation?
More:
http://www.thereminworld.com/silicon_chip_theremin_modifications.html
Linearizing the pitch sensitivity - I found that the upper octave was much compressed and that the highest notes I wanted to play were so close to the antenna that accurate vibrato wasn't possible. A way to linearize the response is to put an inductor in series with the antenna.
http://www.dogstar.dantimax.dk/theremin/thersens.htm
This effect is partially offset by the nature of the LC tuned circuit, the frequency of which depends on the inverse square-root of capacitance. This is the main reason, I believe, why oscillators based on a single pole (only one reactive component, i.e. capacitance) never took hold for theremin use. I, and probably many others, have experimented with RC oscillators in an effort to get rid of those pesky coils; even the ordinary NE555 timer can be used for this purpose. However, in such circuits the oscillating frequency is inversely proportional to capacitance, rather than square-root of capacitance, and the "square-law" effect is correspondingly a lot worse. Another way of looking at this is that sensitivity (dF/dC) of the RC circuits is proportional to 1/C2 instead of 1/C1.5 in the case of the LC circuit.
  • 4
    \$\begingroup\$ at 200-500KHz a half wavelength dipole and such are gigantic. The difference is that the "near-field" of such an antenna is gigantic. This is where inductive and capacitive coupling take place. For this case it means that you do not need a radiator, you just want to promote capacitive and inductive coupling. \$\endgroup\$
    – Kortuk
    Mar 18, 2011 at 6:15
  • \$\begingroup\$ @Kortuk Is inductive coupling relevant here? Wouldn't humans need to be ferromagnetic to inductively affect a circuit by proximity? \$\endgroup\$
    – endolith
    Nov 7, 2014 at 3:07
6
The fact that theremins use heterodyne mixers has nothing to do with RF. The 'antennae' are not antennae in the classical, RF sense. The capacitance explanation is correct.
Capacitors and Theremin 'Antennae'
The simplest type of capacitor is a parallel-plate capacitor. That means the capacitor consists of two metal plates separated by some material called the dielectric. The equation for the capacitance of such a capacitor is C=εA/d, where ε is the permittivity of the dielectric (ε≈8.8541878176..×10^−12 F/m for air).
When you are operating a theremin, your hand is one plate (your hand is effectively grounded), the antenna is the other, and the air between the two is the dielectric. As you move your hand, you vary the capacitance between ground and the antenna. Both hands will affect both antennae, as they act like two plates in parallel, increasing the total area.
The two antennae are at right angles because that reduces the impact your left hand will have on the right antenna and vice versa. For example, as you move your hand up and down above the volume antenna, it maintains a relatively constant distance from the pitch antenna, thus it's contribution to the overall capacitance is constant (and small).
Theory of Operation
Note/Update: Please refer to FredM's Answer for a more detailed description of the oscillator.
Both antennae capacitors are part of two different, complex active LC oscillators. The 'L' refers to inductors, which store energy in a magnetic field; the 'C' refers to capacitors, which store energy in an electric field. In an LC oscillator, energy is constantly flowing back and forth between the two, changing from electric potential to magnetic potential.
The frequency of the pitch oscillator is beyond audio frequencies, so it can't be directly used. The theremin has a third oscillator that operates at a fixed frequency. The pitch oscillator and the fixed oscillator's outputs are fed into a heterodyne mixer, resulting in an output that includes the sum and difference frequencies of the two inputs. The sum frequency is even higher than the original signal, thus it is useless and is filtered out. The resulting signal is a single frequency (plus harmonics) in the audio range.
The frequency of the volume oscillator is used to control how much the audio signal is amplified. As you move your hand, the frequency changes, so the amplifier's gain changes, and thus the output volume changes.
  • \$\begingroup\$ Do you have any idea how Leon Theremin's later instruments would have translated volume-oscillator frequency into gain? I recall hearing (on video) Clara Rockmore (performer) saying that earlier instruments used variable filament voltage to control volume, but that made response sluggish, and newer instruments were better. \$\endgroup\$
    – supercat
    Dec 19, 2013 at 19:24
  • \$\begingroup\$ Based on the schematic @endolith liked to, the Moog Etherwave uses a envelope detector. These are normally used in dirt cheap AM demodulators. I'm not sure how it's being used as a frequency->voltage converter. I wonder if you could get improved response with a PLL. \$\endgroup\$ Dec 19, 2013 at 19:50
  • \$\begingroup\$ @supercat: See google.com/patents/US1661058 ? \$\endgroup\$
    – endolith
    Dec 20, 2013 at 0:27
There is some confusion because there are two common topologies with theremins, however, in both cases the distance sensing mechanism is purely capacitive (electrical / electrostatic, not magnetic or electromagnetic to any significant degree)
The two main topologies are (a) an LC tank oscillator with a series L connected to the antenna forming a series resonant circuit. The antenna L is much larger than the tank L, and the tank C is much larger than the antenna C. Changes to the antenna C are "converted" through the LC resonance in a way that causes these changes (due to the respective tunings of the antenna and tank operating frequencies) into a "virtual" variable inductance seen across the tank inductor - so whilst the antenna resonator is responding to capacitance variation, the tank (oscillators) frequency is being controlled by variable inductance - and the two interact with each other in a complex way that improves musical linearity.
(b) The other common (inferior) topology is where the tank capacitor is directly in parallel with the antenna capacitance, and the oscillator frequency is a simple LC function, and extremely non-linear.
Examples of topology (a) are all theremins designed by Lev Termen, all theremins designed by Bob Moog. Examples of type (b) include Jaycar / Silicon chip theremins and most of the simple rubbish one finds on the WWW.
There are other less common topologies as well...
BTW, the "schematic" at the top of this page is the worst possible kind of type "b" topology
While I believe the first explanation is the "simple" one, I think that the second explanation makes a lot of sense. As @Kortuk stated in his comment, you are operating in the "near-field" region of the antenna. This is the region that doesn't behave quite like what you would expect if you were basing your calculations on the standard far-field antenna radiation patterns.
In the near-field, you have a reactive near-field and a resistive near-field. The reactive near-field is where E and H fields are constantly being built up and collapsed, without the energy leaving the antenna, it is just alternated between the two different field types. By putting your hand near the antenna, you are effectively stealing some of the power that are in these fields.
I think that a good comparison would be a pair of inductors with some mutual inductance. The mutual inductance of the second inductor makes the measured inductance change on the first. The same is happening with the antenna. By putting your hand close to the antenna, you are taking some of the power out of the E and H fields that are alternating in the region, and thus changing the amount of inductance/capacitance that the LC tank circuit is seeing, and detuning the oscillator.
  • \$\begingroup\$ Hmmm.... Can you draw an equivalent circuit? \$\endgroup\$
    – endolith
    Mar 19, 2011 at 14:22
  • \$\begingroup\$ I have no idea. This was a general hand-waving guess based on my limited analog electronics and Emag experience. You could probably pick up an Emag book, or check out a site like this: ece.rutgers.edu/~orfanidi/ewa Be warned, the math gets pretty intense quickly with near-field antennas. \$\endgroup\$
    – mjcarroll
    Mar 23, 2011 at 19:48
