This is my first EAGLE design and I'm looking to add some a number of 2-position screw terminals (3.5mm pitch) PRT-08084.
Problem: I can find the EAGLE part for the 3-position variant named as M03SCREW_LOCK from the Sparkfun EAGLE library. However I cannot seem to find a part called M02SCREW_LOCK.
Will M023.5MM_LOCK be suitable? What should we be looking out for to be sure it's suitable?
  • \$\begingroup\$ if something is not in the library or something that doesnt suit my requirements, I would just go and create my own symbol and layout for that part. it is quite handy with eagle. try \$\endgroup\$
    – dr3patel
    Commented Jun 18, 2014 at 3:53
  • \$\begingroup\$ Please share the library for the pic above Thank You. \$\endgroup\$
    – user58270
    Commented Nov 14, 2014 at 6:58
  • \$\begingroup\$ i found it in the Sparkfun-Connectors/Conn_02/CONN_025MM \$\endgroup\$
    – nacmonad
    Commented Mar 29, 2017 at 19:11
  • \$\begingroup\$ @Nacmonad This question is 3 years old.... \$\endgroup\$
    – DerStrom8
    Commented Mar 30, 2017 at 1:20
  • \$\begingroup\$ Wow its been so long since I asked this question \$\endgroup\$
    – Nyxynyx
    Commented Mar 31, 2017 at 5:37
You should find similar connectors in con-phoenix-350 library.
  • distance between pins
  • pin hole diameter
  • copper pad diameter/area
  • clearance to other parts
    \$\begingroup\$ Although less important, I'd also add silkscreen contents to the list. Some parts have more helpful silkscreen layers than others, to show clearance or mounting orientation, etc. \$\endgroup\$
    – JYelton
    Commented Jun 17, 2014 at 20:08
