I'm trying to understand the behavior of a MOSFET I got at radioshack (Fairchild IRF510).
I have the circuit set up in the way recommended by the datasheet:
The specifications suggest that it should happily support a load resistor of 100Ω. However, an oscilloscope shows the following behavior: (scope hooked up under R_load / above MOSFET, pink is the TTL pulse going to the gate, light blue is the voltage output above the MOSFET)
If I switch the load resistor to something like 7 kΩ, the behavior is much more reasonable:
Why am I seeing a fraction of the voltage, and the initial discharge at switching?
6
The problem is that you're not giving it nearly enough gate voltage. You should give it 10V to get the Rds(on) specified in the datasheet, and at least 7V.
Edit: You must recognize that the curves such as figure 5 (below) are only typical curves. It is folly to assume you'll get a unit that is 'typical'. The Vgs(th) parameter guarantees (2.0V to 4.0V) indicate that the curves can be shifted up or down by a volt or two compared to whatever is typical.
Extrapolate the 25°C curve on Figure 7 downward to 250\$\times10^{-6}A\$ and you can guesstimate the typical Vgs(th) at around 3V. That's also halfway between the guaranteed high and low values for Vgs(th), so it's a reasonable guess. If Vgs(th) on your unit happens to be 4.0V it will meet all specifications as a good unit, but the curves in figure 5 and 7 will be shifted by 1V, meaning it will behave as if it was receiving 4V and you'll get perhaps 100mA drain current. That's if your 5V signal is nominal, but it actually appears to be closer to 4V (4 divisions out of 5 vertically). So worst-case you could be getting more like 0.25mA than the 160mA you need (and worse again at low temperatures). If you take the 6V curve (7V minus the tolerance) and shift that down for low temperature, you're still over 1A so there is some margin for a 0.16A drain current. In other words, you can use the shape of the curves as a guide, but you must not rely on them for guaranteed characteristics. To be conservative, only use a transistor that has guaranteed behavior at 5V Vgs or whatever drive you can give it (a logic-level MOSFET- some are specified with 1.8 or 2.5V drive), which this one is not. /Edit
The square wave-ish signal you're feeding it overshoots a bit then slowly decreases, with a similar time constant to the signal you's seeing (it's right on the edge). Vgs(th) can be as high as 4.0V to give only 250uA, and you need 160mA to pull the drain fully low. This particular unit appears to be on the high side of the tolerance band for Vgs(th). Not sure all Radio Shack's parts are full-spec.
You have confirmed this by the 7K trace. Edit When the drain current is reduced, the MOSFET behaves as expected, so it's simply not getting enough gate voltage for the drain current. It's also marginal with a 7K load, cool it down or find another unit with a slightly higher Vgs(th) and it may fail to fully turn on completely with a 7K load and the ~4V gate drive you appear to be giving it /Edit.
The slow rise time on the 7K is due to ~150pF typical output capacitance and the 7K resistance, for the expected time constant of about 1usec.
  • \$\begingroup\$ I will check this out as soon as I get into work tomorrow. However, FIGURE 5. in the data sheet says I should be able to draw 1A with 5 V_GS at ~15 V_DS. Why do you say 7 V_GS minimum? Also, will you expand on how I 'confirmed this by the 7K trace'? I don't see it. - Thank you for your help \$\endgroup\$
    – Ben
    Commented Jun 20, 2014 at 4:20
  • \$\begingroup\$ @Ben See two edits above for expanded explanation. More gate drive or a logic-level MOSFET will solve this problem. \$\endgroup\$ Commented Jun 20, 2014 at 6:13
  1. Battery may be unable to provide I = V/r = 16 / 100 R = 160 mA for very long. What sort of battery are you using?
    How old is it?
    If you place a 100R across the battery directly what is the battery voltage after a few seconds?
  2. TTL pulse may be AC coupled.
    (ie you say pink is TTL pulse GOING TO the gate. That should also be the one ARRIVING AT the gate but your wording allows a little doubt.)
  • \$\begingroup\$ Thank you for your reply. I'm actually powering it from a DC power supply. The yellow trace on the first scope is the voltage reading above the load resistor. I misspoke, the pink trace is the TTL arriving at the gate. \$\endgroup\$
    – Ben
    Commented Jun 20, 2014 at 21:07
