Find the equivalent inductance looking into the terminals a and b of the circuit below.
(Answer: L(eq)= 7H)
Now I try to transform it to be the following.
Then, I get the following formula :
$$ L\left(eq\right)=4+\left(\frac{1}{9+3}+\frac{1}{\left(10^{-1}+0^{-1}\right)^{-1}+\left(12^{-1}+6^{-1}\right)^{-1}}\right)^{-1} $$
However, $$0^{-1} = Error$$
How do I deal with this question?
  • \$\begingroup\$ By inspection, L4 is shorted out. Re-draw circuit by replacing L4 with short. \$\endgroup\$
    – Marla
    Commented Jun 21, 2014 at 14:16
    \$\begingroup\$ Alternatively, mathematically we can see that \$0^{-1}\to\infty\$ and thus \$(10^{-1}+0^{-1})^{-1}\to0\$ and we can evaluate: $$L_{\text{eq}}=4+\left(\frac{1}{9+3}+\frac{1}{(12^{-1}+6^{-1})^{-1}}\right)^{-1}=7$$ \$\endgroup\$ Commented Jun 21, 2014 at 17:06
L4 = 10 H is shorted. So it can be removed from the circuit.
You have to calculate parallel inductance of
  • 9 H + 3 H (L2 and L3)
  • 12 H (L5)
  • 6 H (L6)
which is 3 H. Then you add the series 4 H (L1) and you get 7 H equivalent inductance.
  • \$\begingroup\$ Since there is a wire across the terminals of L4, no current will pass through L4. Therefore, we can omit the effect of L4 and remove it out? \$\endgroup\$
    – Joshua LI
    Commented Jun 21, 2014 at 14:34
  • \$\begingroup\$ @CasperLi The wire has a inductance that is very small when compared to the L4 inductor. In this particular situation you can omit it. \$\endgroup\$
    – Cornelius
    Commented Jun 21, 2014 at 14:35
Wires actually have a bit of inductance and you could probably get the right answer with your formula by using 0.1uH for the wire, but that's so tiny in comparison to the 10H you might as well ignore the 10H. And it's in series with a few H as well, so another tiny bit won't make much difference.
Hopefully this is enough of a hint.
Leq = 4 +(10x0/10+0)+ ((12x6)/12+6)) Leq = 4 + 12x3 = 4 + 2.4 = 6.4H 12+3
Leq = 6.4H
