I've designed a simple PWM RGB LED slow fader to be used as a garden lighting effect. My circuit works great, but I under-estimated the amount of heat that is generated by the 7805 linear regulator.
It's mains powered, with a 6Vac transformer and a 5V 1A linear regulator. If all the LED's are at full brightness then it draws around 600mA.
I've mounted my circuit board in a plastic enclosure with a transparent lid, and it's rated at IP67 (and I want to keep it that way!).
I've put quite a small heatsink on the regulator, and it takes around 3 or 4 hours of continuous use to get to a temperature that is just about too hot to touch, I'm guessing around 70-80°C.
My plan is to give this to my Dad for him to use in his garden, but obviously I don't want it to melt or catch fire.
My questions are:
- Is this an acceptable temperature for it to operate at?
- Is it likely to get any hotter if left on for longer? I didn't want to test this as I didn't want to damage it, but the datasheet says the operating temp is max 125°C so I guess it would be ok.
- What can I do to make it run cooler, given that I don't want to drill vents into the enclosure and ruin it's IP67 rating?
- If it does happily operate at a high temperature, do I need to be worried about heat conduction through the PCB tracks into other components that may be damaged? Will it melt the solder?
