I am using SN65240PWG4 USB PORT SUPPRESSOR.
This is a part of the schematic: (I have connected pins A (6) and B (8) to D- and D+ USB pins. C and D I must connect to the supply)
Schematic
In this schematic from TI those pins are counted as 2 and 4. and the pins connected to supply are 6 and 8.
Is it an error from Texas Instruments in the schematic?
It appears to be an error, but it really doesn't matter- all four inputs are the same, so long as you ground 1,3,5,7 on the 8-pin package, pins 2,4,6,8 can be interchanged with each other.
