I have a GPS PCB which has regular USB pinouts (GND, +5V, DATA- and DATA+), but in addition has one stranded wire which is connected to USB type A plug. Marked as "USB connector" on the image:
GPS PCB
What is the purpose of this stranded wire? If this is for shielding purposes, then why is it connected in both ends? Doesn't this create a "shielding loop"? In addition, if this matters, there is an aluminium-foil shielding around all five wires:
..and this aluminium-foil is also connected to USB plug, i.e. aluminium-foil and stranded wire are electrically connected.
    \$\begingroup\$ It probably serves the same purpose as the drain wire in an audio cable. See this question I asked about it. \$\endgroup\$ – JYelton Jun 23 '14 at 21:56
    \$\begingroup\$ JYelton, thanks! So the drain wire has exactly the same purpose as aluminium-foil but it's just easier to connect to connectors? Still, I'm bit puzzled how the overall shileding should work. There are three ground "wires"- aluminium-foil, drain wire and black USB GND wire. They are all connected to each other. Now what exactly happens in case of EMI? \$\endgroup\$ – Martin Jun 23 '14 at 23:12
By clicking "Post Your Answer", you acknowledge that you have read our updated terms of service, privacy policy and cookie policy, and that your continued use of the website is subject to these policies.
