I'd be much obliged if somebody could point me to a short ISE workflow tutorial that shows how to implement a simple circuit using VHDL.
As indicated, the tutorial should be short as I'm not interested in all bells and whistles of the ISE GUI: it would be neat if somebody could explain how to do things from the command line in UNIX.
The simpler the circuit the better: a logical and should do.
Thanks in advance for your help.
  • \$\begingroup\$ Is this no good? xilinx.com/support/documentation/sw.../ise_tutorial_ug695.pdf \$\endgroup\$ Jun 25, 2014 at 8:57
  • \$\begingroup\$ @MartinThompson The URL doesn't work for me. \$\endgroup\$ Jun 25, 2014 at 10:43
  • \$\begingroup\$ Hmm. Nor me anymore. The link to tutorials is too but you can browse to them through the support pages..design tools..ISE..tutorials. However I can't find any reference to that PDF anywhere, sorry! There is an ISE 11 version, which might be instructive, the basic flow hasn't changed that much. xilinx.com/support/documentation/sw_manuals/xilinx11/… \$\endgroup\$ Jun 25, 2014 at 12:59
  • \$\begingroup\$ @MartinThompson Thanks. I wouldn't call it a short tutorial... \$\endgroup\$ Jun 26, 2014 at 8:29
  • \$\begingroup\$ I agree. But then ISE is not a small tool! (In fact it's more a pretty toolbox for a variety of sharp, pointy tools :) \$\endgroup\$ Jun 26, 2014 at 11:02
Developing an FPGA is a knowledge based skill. There's a delicate balance between abstraction and understanding, and the reason tutorials tend to be so long is based on the least common denominator for understanding by their audience. No one teaches the process in abstract before 'practical' experience because of some ingrained believe system people have that because tools are GUI based they should be intuitive. The Xilinx development process may be complex enough to belie that belief. Hence you get repetition for rote learning.
To demonstrate you're unlikely to be fulfilled by 'short' tutorials see Command Line Tools User Guide (Formerly the Development System Reference Guide) which is 411 pages long (PDF, 4.9 MB). Chapter 2., Design Flow, is 17 pages long and the numerous flow diagrams it contain are detailed enough you need to zoom in on them.
Try googling with command line based Xilinx FPGA development as search terms. You'll find all sorts of interesting references, threads and the occasional tutorial. You could also note that Xilinx tutorials serve two purposes, both as a map to provide inculcation in their prescribed methodology using their graphics user interface centric tools but also to promote new silicon features and their applications.
Some of the short tutorials you'll find through the search might be Verilog instead of VHDL based, but the only place you'll really find a distinction in the process is in XST (Xilinx Synthesis Technology, the synthesizers), where there are distinctions in modeling language feature support.
There are several threads on the use of Makefiles which enforce a knowledge framework on tool process.
It's likely useful to have on-line access to Xilinx Help (ISE Help) although you'd likely find information faster with Google Search than trying to parse the Help tree or search through Xilinx Documentation.
And as you can see by reading various threads on the subject you're not alone in wanting to learn the actual methodology instead of being inculcated in how cute their tools are or what features they are promoting 'now'. (Tutorials tend to have a short half life).
There's a 32 page tutorial (tutorial.pdf) for a 0-9 seven segment display counter on a fairly modern Spartan-3 FPGA board. From this and the other answer to your question you might get the idea that tutorials are generally target platform specific.
Those found at institutes of higher learning (e.g. FPGA_Design_Flow_Xilinx.pdf, 10.8 MB, GUI oriented, Xilinx tool version specific) also serve to reinforced the idea of platform targets (as well as tutorial half life).
You might expect a tutorial example to be made available for a specific platform target, e.g. Xilinx ISE and Spartan-3 Tutorial or Lab 9 – Tutorial. You'd also note some tutorials are based on incrementally acquiring skills through a series of labs in a particular course.
I'll go for the "low hanging fruit" here.
I'm not going to type out an entire tutorial but I will link you to here:
http://micro-nova.com/mercury/examples/getting-started
The guide uses Xilinx's ISE development suite to show how to blink LEDs for a "Helloworld" application. This guide specifically applies to the Mercury FPGA board. If you have some other board, then it would be a simple matter of changing the environment and adding the circuitry for the LEDs.
If you're getting started in FPGAs, I think this inexpensive board is pretty awesome.
  • \$\begingroup\$ micro-nova Getting Started uses another link: link \$\endgroup\$
    – smajli
    Dec 6, 2022 at 11:17
