I think I bricked two ATmega328Ps when I was trying to burn new bootloaders using Arduino Pro Mini, the USBasp programmer and the Extreme Burner AVR software. I had two ATMega328p with bad booloaders and I intended burn the correct bootloader to the chips.
First I connected the USBasp programmer to my Arduino Pro Mini equipped with an ATmega328P. I verified that communication was good as I could read and write to EEPROM. All was excellent.
I was using the following fuses:
LOW Fuse Byte=0x62
High Fuse Byte=0xD9
Extended=0xFF
Lock = 0xFF
Calibration = 0xFFFF FF8A
Then the following happened:
  1. I killed the 1st chip when I only pressed button ERASE CHIP on the programmer.
  2. I killed the 2nd chip when I wrote the following fuses to it:
LOW Fuse Byte=0xFF
High Fuse Byte=0xDA
Extended=0xFD
Lock Fuse = 0xCF
In both cases I had the following error message:
Cannot Communication with chip
Power On failed
avrdude output similar messages:
RC=-1. No answer...
(avrdude -c usbasp -p m328p -U lfuse:w:0x62:m -U hfuse:w:0xd9:m -U efuse:w:0xff:m )
How can I solve this problem?
How can I reset all the fuses to factory default to make the chips respond again?
  • \$\begingroup\$ Welcome to EE.SE, Sergey! If you don't get any good answers here, try posting your question at Arduino StackExchange. \$\endgroup\$
    – Ricardo
    Jun 25 '14 at 12:22
  • \$\begingroup\$ Makes sense. Either way: how does the Pro Mini come into play in this setup? Do you mean you are trying to burn a bootloader on the ATMegas that are mounted on the Pro Mini boards? \$\endgroup\$
    – RJR
    Jun 25 '14 at 12:26
If I understand you correctly, these are standalone chips?
The fuse values you set have the chips clocked by an external oscillator. Either set up a crystal on a breadboard, or just generate a clock with a PWM signal from your Arduino Pro Mini (in the latter case, you may want to limit your programming speed).
