I'm currently working my way through a beginner's electronics book(electronics for dummies) where i am introduced to RC circuits as shown in the schematic below.
From the book,I am told that initially, the voltage across the capacitor is 0(assuming it's discharged), and that the voltage drop = the voltage rise(kirchoff's law).
When the capacitor is charging
Initially: Because capacitor voltage is initially 0, the resistor voltage is equal to the supply voltage.
Charging: As the capacitor begins to charge, it develops a voltage, so the resistor voltage begins to fall, which in turns reduces the charging current, which in turn causes the capacitor to charge at a slower rate. This continues until the capacitor is fully charged.
Fully Charged:When the capacitor is fully charged, the current stops flowing, the voltage drop across the resistor is zero, and the voltage drop across the capacitor is equal to the supply voltage.
When the capacitor is discharging
(Battery is removed and resistor is connected in parallel with the capacitor). Voltage across resistor is equal to voltage across the capacitor (V[r] = V[c]), therefore the current is given by the equation V[c] / R (resistor value).
Initially: Because the capacitor is fully charged, the voltage is equal to V[s] (Voltage supply), so the current is given by V[s] / R. (Basically the same as V[c] / R )
Charging: As the charges begin to flow from one capacitor plate to the other, the capacitor voltage( and so V[r] ) starts to drop, resulting in a lower current .The capacitor continues to discharge, but at a slower rate. As V[c] ( and so V[r]) continues to decrease, so does the current.
Fully discharged: When the capacitor is fully discharged, current stops flowing and no voltage is dropped across either the resistor or the capacitor.
What i understand
  1. Voltage drop = Amount of volts/voltage used up.
  2. Ohm's law (V = IR) etc
  3. Kirchoff's law ( voltage used up = voltage in circuit / voltage drop = voltage rise)
Questions(Charging):
  1. Why is the resistor voltage initially equal to supply voltage? Is it because there is no voltage going across the capacitor yet? Therefore, as there is no voltage drop across the capacitor, all the voltage from the battery is across the resistor?
As the capacitor begins to charge, it develops a voltage........
2.What exactly does the voltage developed as the capacitor charges refer to? Is it the amount of electrons that begin to accumulate on it's negatively charged plate? What exactly is voltage? seems to suggest that it is NOT the amount of electrons. However, assuming that the voltage developed by the capacitor refers to the voltage rise across the capacitor, WHERE and/or WHAT does the voltage risen actually do? Assuming that voltage is the electromotive force that pushes electrons around, how then does it build up in the capacitor when all that's happening in the capacitor is that electrons are building up in it??
3.Am i correct in assuming that the resistor voltage drops because the capacitor's voltage is increasing? (kirchoff's law where volt rise = volt drop).
Question(Discharging)
As the charges begin to flow from one capacitor plate to the other, the capacitor voltage( and so V[r] ) starts to drop, resulting in a lower current....
1.If the capacitor's voltage is dropping(due to it being discharged), shouldn't the resistor's voltage be increasing due to kirchoff's law? Also,this should therefore INCREASE the current instead of decreasing it, which would then cause the capacitor to discharge even faster?
I apologise in advance for the wall of text above, but i've been scratching my head over this for quite some time now, and it's really eating away at me.
I would appreciate any clarifications i can get.
Thanks!
  • \$\begingroup\$ Does it help to know that \$C\dfrac{dv}{dt} = i\$ i.e. the rate at which voltage rises on a capacitor is proportional to current thru the cap? \$\endgroup\$
    Jun 26, 2014 at 10:15
  • \$\begingroup\$ I've never seen that particular formula before, what do the C,dv and dt stand for? i'm assuming that i = current? \$\endgroup\$
    – Kenneth .J
    Jun 26, 2014 at 10:17
  • \$\begingroup\$ Keep in mind that the capacitor (in theory anyway) is never quite fully charged, but after some point the current will be too small to measure in comparison to Johnson noise in the resistor etc. Each \$\tau\$ (where \$\tau\$ = RC seconds) the current drops to about 37% of what it was previously. So after 10RC seconds (about 10 years for your circuit) it would differ from the battery voltage by about 400uV (still easily measurable, if such ideal components existed). \$\endgroup\$ Jun 26, 2014 at 17:52
Sum of voltages on the passive elements must add up to the supply voltage.
$$ V_{supply}(t) = V_{switch}(t) + V_{resistor}(t) + V_{capacitor}(t) $$
Because of the fact that \$V_{switch}(t) = 0 \$ and \$V_{capacitor}(0) = 0 \$, \$V_{resistor}(0)\$ must be equal to \$V_{supply}(0)\$.
2.What exactly does "the voltage developed as the capacitor charges" refer to?
When you apply a voltage difference between capacitor plates, one plate has more positive potential with respect to the other one. This initiates an electric field field between the plates, which is a vector field, whose direction is from the positive plate the negative one.
There is an insulating material (dielectric material) between these capacitor plates. This dielectric material has no free electrons, so no charge flows through it. But another phenomenon occurs. The negatively charged electrons of the dielectric material tend to the positive plate, while the nucleus of the atoms/molecules shift to the negative plate. This causes a difference in the locations of "center of charge" of electrons and molecules in the dielectric field. This difference create tiny displacement dipols (electric field vectors) inside the dielectric material. This field makes the free electrons in the positive plate go away, while it collects more free electrons to the negative plate. This is how charge is collected in the capacitor plates.
As the capacitor voltage increases, the voltage across the resistor will decrease accordingly because of the Kirchoff's Law, which I formulated above. So, yes, you were correct.
You are missing the fact that, the source voltage is zero (i.e.; the voltage source is missing) in the discharge circuit. Substitude \$V_{supply}(t)=0\$ in the formula above. The capacitor voltage will be equal to the resistor voltage in reverse polarities during the discharge. Together, they will tend to zero.
  • \$\begingroup\$ Wonderful answer, though i just have 1 more question.By reverse polarity, do you mean that Cap Voltage is +9V and resistor voltage is -9V?I understand that it is needed for kirchoff's law, so the sum of both equals 0(source voltage), but how exactly does the resistor get a negative voltage? Is it through the electrons that were stored moving through it? The positive voltage of the cap would then be due to the protons/ positive charge? \$\endgroup\$
    – Kenneth .J
    Jun 26, 2014 at 11:05
  • \$\begingroup\$ Consider a discreet passive component with two terminals/pins A and B. If there is a voltage drop of 9V on this components, it is -9V and +9V at the same time. Voltage is an across variable and it has polarity. Its sign depends on which terminal you take reference of. In your case, if a capacitor is discharging over a resistor, the terminal of capacitor and resistor which are connected to each other will have the same potential level. I used the term "reverse polarity", because, if you run around the circuit from one point to another, you will see that the R and C are reversely polarized. \$\endgroup\$ Jun 26, 2014 at 11:14
  • \$\begingroup\$ +1. My EM course referenced this "stretching" of the atomic structure of the dielectric material. I have never seen anyone else mention that. It was spoken of in the context of conservative fields. You put energy into the system by storing the change in the battery, the dielectric "stretching" stores this energy, and the conservative field generated returns the energy when the configuration is allows for it (i.e. parallel discharge resistor). \$\endgroup\$
    – sherrellbc
    Jun 26, 2014 at 14:33
