This question relates to this incident here, where a women in Australia died from a faulty USB charger that allowed the full 240V mains voltage through the USB cable.
Now from my understanding you would have to be connected to the mains ground or the earth's ground in order to get an electrical shock. Otherwise there wouldn't be a potential that would allow the current to flow through her.
Now according to the article which cites the police she received the shock because she was touching her phone which was connected to the charger and her laptop which was also connected to a charger, as well as her EARPHONES which bothers me the most, apparently she had burn marks on her chest where the laptop was and in her ears. Unfortunately there are no details about the devices that were used. So I'm just assuming below.
Here the picture shown in the article explaining the connection:
Now how would this be possible? The phone must have a metal body which is also somehow connected to the power of the phone. The only phone where I can imagine that being the case are the recent iPhone models where the outer aluminum ring on the side is apparently also acting as the antenna (here and here), maybe other aluminum unibody phones as well. Still, is that even a feasible theory? Wouldn't a metal casing be connected to ground instead? How would a ground in a DC circuit act when suddenly the circuit "becomes" AC?
Then her laptop must have had an aluminum body as well which again must be connected to the ground. Again the only case where I heard about the laptop body be somewhat connected to the circuit is unibody MacBooks where users sometimes feel a tingle when touching the laptop while it is connected to the charger but is that even the case? Again it sounds weird that the laptop's body would be grounded: there is a low DC voltage coming in from the external charger so why would that be needed?
And wouldn't the laptop charger not be faulty as well then? How would it allow the current from the phone charger to flow back into the outlet and complete the circuit? Shouldn't the laptop charger isolate the mains from the DC output circuit?
Then the headphones: WHY would the outer casing of a pair of earphones be connected to the ground in any way and how would electricity even flow through the two sides of the earphones (THROUGH her head to the other side), that sounds like a really unnecessary detour for the current.
If this indeed possible like described by the police would this also be possible by a phone and laptop with plastic bodies?
I would love to see a detailed answer: I'm not that well educated when it comes to mains AC power and safety measures taken to avoid shocks.
