I noticed it's possible to give present a negation value by calling a variable the following:
!A
However I'm trying to imitate an existing part where A has the header line, and B doesn't and it only works if I go at it backwards: enter image description here
While this is what what I want enter image description here
B/!A as oppose to !A/B enter image description here
There might be some sort of syntax I'm unaware of. I've already tried !{A}/B !(A)/B and !A_/B.
Just like the Eagle documentation says, a second "!" in a name ends the inversion bar above the text. For example, if you want "not A, B", the name for that net in Eagle would be "!A!/B". The first "!" starts the inversion bar and the second ends it.
For example, here is the result of "!RESET!/RUN":
