I currently have a 150-1500mA led driver that I sue to power a 30W LED. Driver has adjustable maximum current pins that I can use to change to match the maximum current. I have it set to 1050mA.
I am now considering another driver. Looking into Meanwell LDD-350L datasheet there is this line at the top of the first page:
constant current output: 300mA to 700mA.
This confused me since what use is PWM dimming if you cannot get the full range of values? My current driver has minimum of 150mA but I am able to PWM the LED at very low levels, certainly below 150mA unless the driver is using up the remainder of the power.
How does min / max current specification work in constant current drivers?
Edit:
To add to the answer already accepted, the reason why my current LED driver was rated 150-1500mA is that it has max current select jumpers with 150mA being the smallest selection.
That datasheet is for multiple devices. The LDD-300L is capable of 300mA. The LDD-700L is capable of 700mA. Your device, the LDD-350L, is capable of 350mA. The second page describes the LDD-1000L through LDD-1500L. So the minimum and maximum are for the range of devices, not just a single device.
  • \$\begingroup\$ Ahh, how did I miss that... Thanks for pointing it out! \$\endgroup\$
    – DominicM
    Jul 1, 2014 at 1:23
