In order to safely get the most light out of an LED the best solution is to use a constant current source, this will ensure the LED stays at the right brightness even as its characteristics change as it heats up, changes in your supply voltage or the color of the LED.
A current source can be made from an extremely common and cheap lm317 (buy a bunch on ebay, they are handy) and a resistor. simply utilize this circuit but with an LED instead of a battery. You will need one of these for each LED.
The resistor value can be changed to choose the current which will end up being 1.2/R. so the 24 ohm resistor in that circuit gives 1.25/24 ~= 0.050amps or 50ma. using an easier to find 47 ohm resistor will give a healthy 26ma which is a good place to start for a bright LED. You can then decrease the resistor value which increases the current until you reach your desired brightness.
When using this scheme you can ignore the voltage rating of the LED and of the supply, they are irrelevant. You don't even need a regulated supply. You just need to worry about the current rating of the LED which can be found in the datasheet. Once you find that, calculate '1.25/datasheet current' and that gives the minimum resistor value you can use and will give maximum brightness, don't use resistor values smaller than that or you risk damaging the LED. (note: some LED datasheets may assume you are heatsinking your LED, so reduce the current if it is getting too hot until you can put it on a heat sink)
