My current project involves producing 200KHz PWM waveforms using timer 1 in fast PWM mode. I would like to increment a 16-bit counter every time the timer overflows (every 5μS)
volatile uint16_t count;
ISR(TIMER1_OVF_vect)
++count;
The microcontroller is an ATmega8 running at 16MHz, leaving only 80 cycles for servicing the interrupt and incrementing the variable before the next interrupt fires. Looking at the compiled code...
00000890 <__vector_8>:
890: 1f 92 push r1
892: 0f 92 push r0
894: 0f b6 in r0, 0x3f ; 63
896: 0f 92 push r0
898: 11 24 eor r1, r1
89a: 8f 93 push r24
89c: 9f 93 push r25
89e: 80 91 c9 00 lds r24, 0x00C9
8a2: 90 91 ca 00 lds r25, 0x00CA
8a6: 01 96 adiw r24, 0x01 ; 1
8a8: 90 93 ca 00 sts 0x00CA, r25
8ac: 80 93 c9 00 sts 0x00C9, r24
8b0: 9f 91 pop r25
8b2: 8f 91 pop r24
8b4: 0f 90 pop r0
8b6: 0f be out 0x3f, r0 ; 63
8b8: 0f 90 pop r0
8ba: 1f 90 pop r1
8bc: 18 95 reti
...I found out that the generated interrupt service routine could easily be optimized further. This is the first time that I have tried to include inline assembly to a C program, and I have found out that learning to do so is unnecessarily frustating and requires understanding some fairly esoteric syntax. I would like to know how to access uint8_t count
within the inline assembly (as the variable is allocated statically unlike in every answer that I have seen on the web). Is the code otherwise OK, or have I missed something else?
ISR(TIMER1_OVF_vect, ISR_NAKED)
asm volatile("push r24" "\n\t"
"in r24, __SREG__" "\n\t"
"push r24" "\n\t"
"push r25" "\n\t"
"lds r24, %A0" "\n\t"
"lds r25, %B0" "\n\t"
"adiw r24, 1" "\n\t"
"sts %B0, r25" "\n\t"
"sts %A0, r24" "\n\t"
"pop r25" "\n\t"
"pop r24" "\n\t"
"out __SREG__, r24" "\n\t"
"pop r24" "\n\t"
"reti" "\n\t"
: "=r" (count) /*this does*/
: "0" (count)); /*not work*/
As a side note, is there a way to make the compiler reserve a register pair specifically for uint8_t count
, as that would allow reducing the ISR lenght by at least 6 instructions (by eliminating both lds and sts instructions, a push to stack, and a pop from stack)?
