I have a small buck dc-dc voltage converter that has two aluminium body capacitors mounted on the pcb surface. The top reads something like this: 220 HFP 1J9
Here's a photo of it... enter image description here
I want to know what is the max voltage for this capacitor. I see similar circuit boards that have 35v or 50v capacitors (mostly 35v) but how do I know the voltage rating of this capacitor.
I understand the meaning of 220 that is 220uf but what does HFP and 1J9 means?
Thanks in advance.
  • \$\begingroup\$ Welcome! It might be helpful to provide a well-focused photo of any and all markings on the part. You can provide a link to it. \$\endgroup\$ Jul 4, 2014 at 2:25
  • \$\begingroup\$ added picture for it \$\endgroup\$
    – user46769
    Jul 4, 2014 at 3:02
The photo is helpful. I suspect it's a Chinese part that is numbered similarly to the Panasonic FP series.
That would make it a 220\$\mu\$F/50V 105°C RoHS low-impedance part, size code "G" (10mm⌀\$\times 10.2\$mm tall)
Of course if it's not a genuine Panasonic part (and I don't think it is, the markings don't look like the Panasonic parts I have) the characteristics may not be the same (and chances are they will be, at best, equal).
