I am constantly getting verification errors with avrdude and atmega168. I googled a lot, but everyone is getting them at first byte, whereas I am getting them at random bytes:
avrdude: verifying ...
avrdude: verification error, first mismatch at byte 0x0692
         0x91 != 0x8c
avrdude: verification error; content mismatch
Sometimes it works, sometimes it doesn't. I noticed that if one hex file doesn't work once, it won't work at all, unless I will change something in code, thus changing the hex file. It happened with multiple processors and two programmers.
  • \$\begingroup\$ Lack of decoupling capacitors causing the chip to fwibble? \$\endgroup\$ – Majenko Jul 6 '14 at 17:50
  • \$\begingroup\$ nope, they're there. \$\endgroup\$ – gumol Jul 6 '14 at 17:52
  • \$\begingroup\$ Have you been reprogramming it a lot? Are the power supply voltages in spec? What programmer are you using, which baudrate? \$\endgroup\$ – jippie Jul 6 '14 at 18:18
  • \$\begingroup\$ Did you tried with other uC? @jippie the write/erase cycles are 10.000 for the flash memory according to the datasheet. Of-course this varies, and can be the case, but I think the changes are small. \$\endgroup\$ – Diego C Nascimento Jul 6 '14 at 22:17
