I have written this program for GPIO External Interrupt but it doesn't work. look at the program:
/* Includes ------------------------------------------------------------------*/
#include "stm32f10x.h"
/* Private functions ---------------------------------------------------------*/
GPIO_InitTypeDef GPIO_InitStructure;
EXTI_InitTypeDef EXTI_InitStructure;
NVIC_InitTypeDef NVIC_InitStructure;
void GPIO_Configuration(void);
void EXTI_Configuration(void);
void NVIC_Configuration(void);
* Function Name  : main
* Description    : Main Programme
* Input          : None
* Output         : None
* Return         : None
* Attention      : None
int main(void)
    GPIO_Configuration();
    NVIC_Configuration();
    EXTI_Configuration();
    /* Infinite loop */
    while (1)
* Function Name  : GPIO_Configuration
* Description    : Configure GPIO Pin
* Input          : None
* Output         : None
* Return         : None
* Attention      : None
  RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOB , ENABLE);
 *  LED1 -> PB0
  GPIO_InitStructure.GPIO_Pin = GPIO_Pin_0;
  GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_PP;
  GPIO_Init(GPIOB, &GPIO_InitStructure);
    /* PB2-> Input */
    GPIO_InitStructure.GPIO_Pin = GPIO_Pin_2;
  GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;
    RCC_APB2PeriphClockCmd(RCC_APB2Periph_AFIO, ENABLE);
  GPIO_EXTILineConfig(GPIO_PortSourceGPIOB, GPIO_PinSource2);
  EXTI_ClearITPendingBit(EXTI_Line2);
    EXTI_InitStructure.EXTI_Mode = EXTI_Mode_Interrupt;
  EXTI_InitStructure.EXTI_Trigger = EXTI_Trigger_Rising;
  EXTI_InitStructure.EXTI_Line = EXTI_Line2;
  EXTI_InitStructure.EXTI_LineCmd = ENABLE;
  EXTI_Init(&EXTI_InitStructure);
  NVIC_InitStructure.NVIC_IRQChannel = EXTI2_IRQn;
  NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelSubPriority = 1;
  NVIC_InitStructure.NVIC_IRQChannelCmd = ENABLE;
  NVIC_Init(&NVIC_InitStructure);
void EXTI0_IRQHandler(void)
    if ( EXTI_GetITStatus(EXTI_Line2) != RESET ) {
      GPIO_SetBits(GPIOB , GPIO_Pin_0);
#ifdef  USE_FULL_ASSERT
  * @brief  Reports the name of the source file and the source line number
  *   where the assert_param error has occurred.
  * @param  file: pointer to the source file name
  * @param  line: assert_param error line source number
  * @retval None
void assert_failed(uint8_t* file, uint32_t line)
  /* User can add his own implementation to report the file name and line number,
     ex: printf("Wrong parameters value: file %s on line %d\r\n", file, line) */
  /* Infinite loop */
  while (1)
#endif
      END FILE
and this my circuit:
I have even pulled-down the PB2 but doesn't work, again. the program correctly build and download (without any error or warning).
What's the problem? any idea?
  • \$\begingroup\$ Add a pull down resistor to the input pin, i.e. \$10k\Omega\$ between PB2 and ground. And please add a resistor for that LED, \$1k\Omega\$ is ok, if it turns on it will probably fry. Maybe your circuit does not work because you fried it already... \$\endgroup\$ – Vladimir Cravero Jul 9 '14 at 16:28
  • \$\begingroup\$ Moreover, your interrupt routine turns on the led but it's never turned off. The odds you burnt it are quite high I'd say. \$\endgroup\$ – Vladimir Cravero Jul 9 '14 at 16:29
  • \$\begingroup\$ @VladimirCravero As I said, I have already pulled-down it but... No, The LED is ok. yeah, I know but it doesn't work for one time even. \$\endgroup\$ – Roh Jul 9 '14 at 16:30
  • 4
    \$\begingroup\$ I believe your code is wrong. Your interrupt is connected to EXTI2 although the vector for the handler is looking for EXTI0. Change " EXTI0_IRQHandler" to " EXTI2_IRQHandler" Let me know if this fixes it \$\endgroup\$ – Funkyguy Jul 9 '14 at 17:50
    \$\begingroup\$ @ShannonStrutz Greeeaaaattttzz! absolutely you are right! I changed it and now it's working! put your answer because I want to select your answer and +1 \$\endgroup\$ – Roh Jul 10 '14 at 3:46
Your interrupt is connected to EXTI2 although the vector for the handler is looking for EXTI0. Change EXTI0_IRQHandler to EXTI2_IRQHandler
